Results 1 to 10 of 22
Thread: Microchip lead times
    5,571
    Default Microchip lead times
    Does anybody know what's going on there? Most of the mid-range PICs that I've been looking up recently seem to have low inventories at the usual vendors (mouser, digikey and microchip themselves) with 40-52 week lead times.
    Nov 2019
    Edmonton
    136
    Default Re: Microchip lead times
    The worldwide shortage of semiconductors is primarily the result of China hoarding chips due to sanctions. Note, domestic China companies would not be impacted by this since they do not sanction themselves.
    5,571
    Would it be hoarding, or is it more likely that fabs are simply not scheduling runs for IC's that they can't sell?
    5,074
    I work for a company that is tied tightly to the production of ICs. We have seen a HUGE increase in demand for DRAM driven by the Video card market. It seems the video cards are great platforms for processing cryptocurrency. This has driven demand for DRAM far beyond production capacity. IC Manufacturers have shifted production to DRAM and GPUs. This means less production capacity is available for other forms of devices. Add to this an explosion of demand from the smartphone, AI and auto industry, you get a situation where the fabs just cant keep up. The number of new fabs under construction is amazing but the lead time for new production facilities is multiple years and billions of dollars in investments.
    While it is possible that China is hording production capacity, we are seeing every fab running at capacity and new processing systems are being installed at a rate not previously seen.
    IMO: Thank Crypto for your problems.
    7,089
    Ford is stock piling vehicles due to chip shortages .
    https://www.freep.com/story/money/ca...ge/7175158002/
    5,571
    But the Microchip PIC processors that I searching are quite old-school, most have been around for quite a few years, and are probably not made on any leading-edge fabs. Are fabs making those old parts capable of swiveling to making DRAM or other newer, high-density products, or were those fabs moth-balled during the Covid pandemonium? I wonder what is really going on.
    Nov 2019
    Edmonton
    136
    The hoarding was unexpected and is causing "side effects" such as automotive shortages, DRAM shortages, etc. Many tech firms in China are concerned the sanctions will widen and affect them. So they went out and purchased everything they could in the supply channel. Overnight, the stock was cleaned out and all the manufacturers were caught off guard. Unfortunately, it will take some time to restock.
    5,571
    Hmm...just like I was thinking of doing with the PIC parts that I'm using. Fortunately, I have as many as I need already from over the years, and the particular parts that I want have various substitutes (even though those substitutes are not always ideal).
    5,074
    You would be surprised what we are getting out of those old machines. About a third of the DRAM layers are done on the 20 year old machines
    Nov 2019
    Edmonton
    136
    Unfortunately, it is quite expensive to upgrade a fab to a new node. However, are are a lot of legacy parts still in demand so I think companies will continue to operate their older fabs for a while.
    The new nodes are incredible though. 5nm is coming. It is amazing what you can do the a square mm of silicon now. And you can fit 70k of those on a single wafer.
