Results 1 to 7 of 7
Thread: Basic Power Protection - newbie
    Dec 2020
    13
    Default Basic Power Protection - newbie
    Hi guys,
    Really enjoying this forum and learning so much but very much a newbie here. I've built a couple controllers and have my first pixels and strip up and running and have create a couple shows in xlights. Now I'd like to bring my DC props into the mix but am not ready to give up being able to very easily control them via many and various ways via smarthome IoT. I know there are options using MQTT but I already have many things wired and in place and am wondering if I could leave these devices hooked up to the DC power sources that they already run via IoT and simply ADD an additional pixel2things/espixelstick and power source or e1.31 control. To do that I'd need to understand a little more about power protection/isolation I think.. and you are about to see my very first schematic (so please go easy).
    Given the poorly and possibly improperly drawn schematic below which is supposed to depict a DC motor and two distinct 5v DC power sources, how can I protect each of the power sources in the extremely rare event both get power at the same time? Could I simply add inline diodes to stop any reverse flow?
    Here are some of the devices (IoT controlled) - https://www.youtube.com/watch?v=G_PKdBSXT-g
    ...and my first xlights show (I have since learned how to use timing bars) - https://www.youtube.com/watch?v=5OhazVRG59c
    Jan 2021
    96
    Default Re: Basic Power Protection - newbie
    Optocouplers.
    5,486
    Quote Originally Posted by 1pet2_9 View Post
    Optocouplers.
    What are you talking about? That's nonsense.
    5,486
    Quote Originally Posted by asago View Post
    Hi guys,
    I think that two in-line diodes (one between each of the power supply +5 outputs and the motor) would be the easiest option.
    Dec 2020
    13
    Quote Originally Posted by P. Short View Post
    Thank you! I was thinking perhaps it might be that simple...
    Jan 2021
    96
    By optocouplers, I meant optocouplers. I don't speak in secret code.
    5,486
    Maybe not secret code, but nonsense anyway. The original question was about power isolation - ensuring that there wouldn't be any problems if the outputs of the two supplies were at different voltages (or, indeed, that one was turned off), and optocouplers would have little, if any, role in addressing that issue.
