Results 1 to 6 of 6
Thread: Vixen Exports to FPP
    Sep 2017
    39
    Default Vixen Exports to FPP
    Hello, I wasnt sure if this was the place for this. I have 1 of my 10 sequences that I am trying to export to FPP i go through the motions and export to FPP 2+. But when I try to open the sequence in FPP it causes FPP to restart and shows a time of all 0s. If I change the export to version 1 it works but then is uncompressed. All of my other sequences work fine. Any ideas or what logs can I provide to help troubleshoot. Thanks
    Edit I tried this from Vixen 3.7u1 and u2 today.
    4,964
    Default Re: Vixen Exports to FPP
    known issue. fixes are in progress. your solution is the current workaround.
    8,272
    That problem should have been fixed in the release that came out today.
    Sep 2017
    39
    I saw that in the change log so I went and exported my problem sequence this afternoon and still didn't work after the upgrade to Update 2. I'll have some time tomorrow to try again and can report back. Thanks!
    Sep 2017
    39
    Alright, to update this thread. I used the Export under the Main Vixen window (not within the sequence itself) and it looks to have worked today. Yesterday I did the export within the sequence and saved it locally then copied it to FPP and that did not work. But using the Export wizard did go through. Thanks!
    Maryville, Illinois
    1,939
    I am unsure why it would be different between the two. They both use the same logic under the covers to create the files. The wizard just does it in bulk.
