Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: SSR vs TIP31
    Oct 2013
    Gautier, MS
    252
    Default SSR vs TIP31
    I've been doing some re-thinking of my setup and have been reading up on TIP31 NPN transistors. I am thinking about using dumb RGB strips (12v2A) as lights, 12v adapter to provide power to the strips and Cat5e cable to send control signals to the transistors. This way I can use only a few extension cords to provide the 110VAC to the elements as opposed to a whole yard full of spaghetti.
    I should able to build a couple of small PCB's and mount them in Carlton A238 utility boxes.
    Any thoughts or suggestions?
    FYI: this setup will only be used on a simple on-off setup.... I am not doing any dimming or fades! So, plz no comments about TLC5940's or DMX/Renards
    5,483
    Default Re: SSR vs TIP31
    Don't forget heatsinks, as those parts are going to run hot with 2A of collector current. And you're going to need to give it a lot of drive in order to make sure that it is truly driven into saturation (if you don't, the power dissipation is going to go up).
    Oct 2013
    Gautier, MS
    252
    Good point. Thanks
    Malden MA
    992
    I'd look into N channel FETs instead. Much lower dissipation...
    /mike
    Las Vegas, Nevada, U.S.
    2,156
    Yeah^
    Fets act on the voltage level and just see the high or low signal and dont need current running though them like a npn or pnp does.
    Theses links might be interesting to you
    heatsync
    http://www.taydaelectronics.com/heat...aluminium.html
    Projects:
    Videos
    Jan 2011
    Warren, NJ
    1,756
    Another option is a low cost, logic level, low resistance, n channel mosfet http://www.taydaelectronics.com/irlu...lu024npbf.html
    Sep 2013
    Newhaven, East sussex, uk
    437
    Hi there. The irlz14n are good choice. Depends on whether you are using full length strips or not but these are rated at 10amps a piece.
    They are my choice in my build.
    Hope this helps
    5,483
    I would not use the IRF730 for a 2A load. You would more than a 5V Vgs in order to guarantee that the part will pass 2A, and then the power dissipation of the transistor would be a bit higher than with other possible transistors. The part that masterful mentioned is a much better part for this application, although I don't know the relative prices.
    Other parts to consider are the FQPF13N06L or the FQPF20N06L, which are not too expensive and have good on-region characteristics (i.e. they don't require high Vgs values to attain low Vds values for the current levels in question).
    Edit - the part that jklingert mentioned is also a good part with decent prices at tayda.
    Oct 2013
    Gautier, MS
    252
    My thought is to use an Arduino Uno in combination with 74HC595's. I would run a serial USB cable out to a box in the yard housing an ATX power supply and the Arduino. From there I run short lengths of wiring to the display pieces. Each piece contains a single 10ftRGB dumb strip. The strip's paperwork says it draws 2A, but I'm assuming that that would be with all LEDs on
    Oct 2013
    Gautier, MS
    252
    (cont,) so in actuality each TIP31 would only be drawing about 0.667A as it would only be controlling 1 channel of the strip
