Results 11 to 16 of 16
Thread: Export .FSEQ of only one controller
    Sep 2020
    Brescia (Italy)
    131
    Default Re: Export .FSEQ of only one controller
    yes, I will read the article.
    now i extracted a couple of .fseq lises, i noticed that when playing from FPP the lights flicker continuously. Could it be due to the .fseq extraction? or some setting in FPP? because if I run the sequence directly from the Vixen on PC I have no flickering.
    8,655
    Do you still have vixen running when trying to play from FPP? If you do, you need to make sure the controllers are disabled in display setup. Otherwise both Vixen and FPP are sending data to the controllers and causing confusion.
    I'm not sure what you mean about extracting the fseq file. FSEQ files are ready to use once vixen creates them.
    Sep 2020
    Brescia (Italy)
    131
    oops... sorry, you're right; as I was testing with both FPP and Vixen, I had them both open. Now with Vixen closed, it works like a charm.
    Thanks again for your help
    Oct 2021
    Palatine, IL
    4
    I have a question, and i think this thread works to ask it in.
    is there a way to export the .fseq for 1 song to a folder for each controller
    so for example if I 10 controllers
    is there a way that it could
    create folder 1 and put controller 1 fseq in it then create folder 2 and put fseq 2 in it ... etc...
    the only way that i have figured out now is to do the export 10 times with only seleting the controller and the folder for that controller
    6,455
    For vixen, that is pretty much it. Ten export with only the desired controller selected and then move the result into the desired folder.
    2023 - 1 new song. Taking a break from expansion.
    Maryville, Illinois
    2,224
    There are a couple threads on this topic going.. For continuity, I gave this reply in one of the others.
    I do this with mine. You should use the export wizard from the main admin screen so you can do multiple sequences at once. I only have 4, but I setup an export profile for each FPP instance. The profile has all the sequences for that instance and just the controller(s) that go to it. You can specify a target folder or an fpp instance. Then I run each export profile to export the full set. Each set will start at channel one and have just the controller(s) you select and the channel count will start at one and contain all the channels for the selected controllers. I export mine directly to the FPP instances that are networked to my computer via samba so I don't have to do other copying.
    This is an item that is high on my list to better automate after the season.
