Results 1 to 7 of 7
Thread: Set pixel output percentage?
    Nov 2018
    Fairfax, Virginia
    77
    Default Set pixel output percentage?
    Is there a way I can put a default pixel output in sequences? I'd like to set my max at 30% for everything.
    Kansas City Missouri
    2,756
    Default Re: Set pixel output percentage?
    If you have a Sandevice controller you can set it there.
    Aug 2013
    Surprise, Az
    665
    Yes, you can... it's the dimming curve
    Here's a good explanation and example http://doityourselfchristmas.com/for...eview-brighter
    Nov 2014
    Close to Hillsboro, OR
    616
    Falcon controllers have even more capability (I don't have any, but I've seen several topics before, and I've seen screenshots -- I think a Falcon will let you adjust from 0% to 100% in 10% increments).
    3,057
    The Falcons have the ability to set the max brightness level on each output port.
    This is very handy when you have 95% of your pixels that are "too bright", but a small percentage need full power.
    Live, Laugh, Love.
    4,999
    Actually, the Falcons can set the intensity per virtual string. This means you can have multiple brightness setting on a single string.
    3,057
    I've gotten to the point where a virtual string is the same as an output port in my mind. A great idea that has saved my backside many a time when it came to prop placement and manipulation.
    Live, Laugh, Love.
