Results 1 to 8 of 8
Thread: "Neon" Strip Lights for Outlines
    Dec 2020
    102
    Default "Neon" Strip Lights for Outlines
    Is anybody using "Neon" strip lights like the one in the link below? It seems they would produce nicely diffused light, make storage a lot easier, they don't require heavy PVC pipes (makes mounting easier), they use WS2815 which should be more reliable, etc. The biggest drawback is the pretty high price of around $10/meters. I don't know why those things are so expensive.
    https://www.aliexpress.com/item/4000...106b6cbfi0xXxW
    4,956
    Default Re: "Neon" Strip Lights for Outlines
    the drawback for me is maintainability.
    Dec 2020
    102
    You mean if an LED breaks? They are WS2815 LEDs so two consecutive LEDs would have to break. I would assume that is kind of unlikely until it gets pretty old but frankly I have no experience with this. Just asking...
    Regarding repairing, I have seen quite a few posts on this forum about repairing pixels. How are you actually doing this? Cutting the bad pixel out, cut a good pixel out from a good string and connect everything back together using some shrink wrap to protect is from water?
    4,956
    yes but getting a strip like that sealed again is no fun
    Mar 2017
    Indiana
    186
    When I build the giant mount in my show, I wanted a different look and used a similar Neon style light strip. https://www.aliexpress.com/item/32823372160.html They do look great and have a very smooth appearance. Part of the expense is the heavy silicon tube they are in. Each set weighed quite a bit more than I expected.
    I did a lot of custom cutting, soldering, and silicon sealing building the mouth. So far they have been reliable with no issues. I do have them permanently mounted to a grid inside the frame, so they don't move or flex much.
    44
    I am still looking for ones that are truly RGB+CCT (I found some that SAY they are, but digging into them it turns out they are blended RGB). If I am going to permanently mount things (or for some displays) have white, true white, would definitely increase the WAF. I have not seen pixels that do this either. Admittedly most are pretty decent at combining the RGB to make white, but I would still prefer a dedicated capability to it.
    Dec 2020
    102
    I am really surprised to hear that people put PVC pipes permanently on their home. I would not even put those 'neon' strip lights on permanently, much less PVC pipes. There is one house in the neighborhood that has a huge display and is still taking down the Christmas lights but even they don't have anything installed permanently.
    I did see strips that have white LED in addition to the RGB lights. I think they were WS1815. Check the link below. I think they mention such a strip light.
    https://www.derunledlights.com/the-d...k9822/#subtt-7
    Personally, I have not use for those as I just want to do lights for Christmas (and maybe Halloween later on) but I see how a white LED can be important (with all the different Kelvins) for permanent installations.
    44
    @munu:
    I have almost nothing mounted "permanently" (other than some staked spot lights) but there is always talk about a couple areas where the lights could be used for decoration at some times of the year, general purpose lighting, etc...
    There are a bunch of RGBW or RGB+CCT light strips out there, like what you linked (usually SK6812 but I think there are others) but I have yet to see one that has been made into a neon strip directly and I am not as confident with putting those into one of the silicone sleeve diffusers for a similar effect.
