Thread: Looking for High Powered WS2812B LED's
    Virginia
    48
    Default Looking for High Powered WS2812B LED's
    Looking for a 10 Watt or more Addressable RGB LED, I found this on Amazon but it says not available.
    RGB High Power LED 10 Watt on Aluminum Circuit Board, WS2812B, SK6812, PL9823 Compatible
    Tindie had this but now retired 10W RGB LED Soldering Kit Module With Heatsink
    Found These in Germany, POWER-DOT 20W, WS2811 COMPATIBLE
    They Also have a 3 Watt Version POWER-DOT 3W, WS2811 COMPATIBLE
    With Shipping and Euro Conversion makes them a bit pricy
    Tindie had several Kits that used a standard 10 watt RGB but they are no longer available..
    Did I miss the boat?
    Jan 2021
    3
    Default Re: Looking for High Powered WS2812B LED's
    There are several floods available here. https://buildalightshow.com/search?c...earch&s=floods
    44
    Not sure how far you are willing to DIY but you could buy just some WS2811 chips themselves and drive your own RGB LEDs. Those are available all over and are pretty cheap (Adafruit has 10 for ~$5) for example.
