Results 1 to 5 of 5
Thread: Multiple Mega Tree Issue
    Oct 2015
    61
    Default Multiple Mega Tree Issue
    Hey Everyone,
    I am having an issue with my mega trees (they are actually mini-trees, with 10 strips of 20 pixels on each). I have these 4 trees connected to an AlphaPix 4 controller, and all are power-injected. They are each set up as their own universe, with 200 pixels in each:
    I set up the trees in Vixen, and directly mapped them to the controller with all 2400 patch points.
    For some reason, everything seems to work except for the second to last universe. The last one works, and the first 6 work. I have no idea why. The 7th universe sends color, but it's just static and doesn't move. It's rather odd. Anyone have any ideas?
    Oh, and if I swap the universe numbers from the 1/2 and 7/8 lines in Vixen, a different output starts to not work properly. I also ran tests from the controller itself, and all the trees/pixels received the proper colors.
    Aug 2013
    Surprise, Az
    668
    Default Re: Multiple Mega Tree Issue
    I don't know this controller, and the screen shot doesn't indicate... Each tree would need 2 universes, which is properly setup in Vixen. Does your controller indicate somewhere that it is using 2 universes for each output?
    5,090
    Sounds like a patching issue in Vixel or your sequence is not applied to the elements properly.
    Oct 2015
    61
    Quote Originally Posted by Popo-B-Trippin View Post
    Well, all of the outputs from the controller seem to work fine somehow, the only setup of outputs and universes are in the picture I attached. Supposedly, they automatically rollover to the next universe once they pass 510. The first three outputs work perfectly and the 4th is the one with the issues. But when I swap the universe numbers around in Vixen, the 4th output works perfectly and a different output stops working. This leads me to believe it is something in Vixen, but all 4 of the Mini-Trees are set up identically...
    Oct 2015
    61
    Agreed, but I'm not sure what to look for. In the preview screen, all 4 trees have the exact same number of pixels, all the trees have the same number of outputs, and all are mapped the same in the controller. Just for some reason whatever I put in Universe 7 doesn't seem to want to work. I tried completely recreating the controller, and the tree, with the exact same issue occurring.
