Thread: motor needed
    Nov 2017
    13
    Default motor needed
    Apparently the motor in this Santa is toast. It will hum periodically but does not move the arm. Any ideas on where I can find another one or get this one rebuilt? The only markings on it are 629 156. Thanks
    7,000
    Default Re: motor needed
    BREVEL MOTORS are a common goto for replacement motors .
    PICS
    Nov 2017
    13
    Thanks. That looks like one of them will work.
    Nov 2017
    13
    I lucked out after all. While I had the top half off, I started checking the gears on it, and one of the them was stuck. I used a flat tip screw driver to get it to spin, and now it works great. I guess after 50 years or so the crud had built up, but a little WD 40 took care of that.
