Results 1 to 4 of 4
Thread: Audio soundwave bar scale
    Nov 2013
    Osceola, IN
    335
    Default Audio soundwave bar scale
    Accidently enlarged the audio soundwave bar and now it won't scale back down. It stops after the timing numbers get to I assume minimum font. Can still drag it and make it bigger, won't get any smaller than pictured now. Short of uninstalling and reinstalling, any way to fix this?
    Happened in 3.7 update 1, persists after installing 3.7U2
    -Wife-certified nerd
    8,272
    Default Re: Audio soundwave bar scale
    Uninstalling and reinstalling wonít fix it. Donít waste your time on that. Stand by for a few while I try to replicate and come up with a better answer.
    Maryville, Illinois
    1,939
    The waveform resizes the same way the timing marks do. Hover your mouse between the bottom of the waveform and the top of the timing marks. Somewhere in there you will see the mouse pointer it turn to a flat resize bar and you can drag the size of it smaller.
    Nov 2013
    Osceola, IN
    335
    Got it, thanks for the quick reply Jeff!
