Thread: Crashing and burning.
    central MO
    85
    Thumbs down Crashing and burning.
    I have been going sequence to sequence just making small adjustments as my display is on a different house this year and when I attempted export the program will crash. Any sequence. Restarted program. Same issue. Restarted computer. Same issue. Also when attempting to load system display panel. It crashes. I have over 2 dozen sequences I need to export to controller and can not get anywhere. Any help will be awesome!
    8,272
    Default Re: Crashing and burning.
    post the logs. The fatal log will generally contain the reasons for a crash.
    central MO
    85
    I checked there to get that prepared to shared but there’s no recent files being generated. Last file was from 2018
    8,272
    Just to make sure, use the menu item on the vixen administration screen. System - Logs. Sometimes when you manually go looking for them, they're not where you expect to find them. Using the menu item takes you to the copy of the logs vixen is currently using.
    central MO
    85
    11/13/2020 16:01:31.012 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
    at System.Reflection.RuntimeModule.GetTypes(RuntimeMo dule module)
    at SystemReflection.Assembly.GetTypes()
    at System.Linq.Enumerable.<SelectManyIterator>d__17`2 .MoveNext()
    at System.Linq.Enumerable.WhereEnumerableIterator`1.M oveNext()
    at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
    at System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source)
    at Vixen.Export.Export..ctor()
    at VixenModules.Editor.TimedSequenceEditor.ExportDial og..ctor(ISequence sequence)
    at VixenModules.Editor.TimedSequenceEditor.TimedSeque nceEditorForm.exportToolStripMenuItem_Click(Object sender, EventArgs e)
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripMenuItem.OnClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.ToolStripDropDown.OnMouseUp(M ouseEventArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.ToolStripDropDown.WndProc(Mes sage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Reflection.RuntimeModule.GetTypes(RuntimeMo dule module)
    at System.Reflection.Assembly.GetTypes()
    11/13/2020 16:01:49.564 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:02:21.882 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    at VixenModules.App.ExportWizard.BulkExportWizardData .get_Export()
    at VixenModules.App.ExportWizard.BulkExportWizardData .CreateDefaultProfile()
    at VixenModules.App.ExportWizard.BulkExportCreateOrSe lectStage.StageStart()
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    11/13/2020 16:02:30.943 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    central MO
    85
    11/13/2020 16:24:16.603 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:28:08.823 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:40:37.245 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    at System.Linq.Enumerable.WhereSelectEnumerableIterat or`2.MoveNext()
    at System.Linq.Enumerable.<CastIterator>d__97`1.MoveN ext()
    at VixenApplication.DisplaySetup..ctor()
    at VixenApplication.VixenApplication.<SetupDisplay>d_ _68.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.ExceptionServices.ExceptionDispatch Info.Throw() at System.Reflection.RuntimeModule.GetTypes(RuntimeMo dule module)
    11/13/2020 16:41:53.609 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:45:11.323 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    central MO
    85
    11/13/2020 16:45:36.154 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:48:07.892 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:48:22.258 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    at VixenModules.Preview.VixenPreview.VixenPreviewSetu pElementsDocument..ctor(VixenPreviewControl preview)
    at VixenModules.Preview.VixenPreview.VixenPreviewSetu p3.VixenPreviewSetup3_Load(Object sender, EventArgs e)
    11/13/2020 16:49:01.366 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:50:41.040 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:51:15.884 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    11/13/2020 16:54:26.635 [VixenApplication.Program] An application error occurred. Please contact the Vixen Dev Team with the following information:
    8,272
    That's better.
    You've got a problem with the vixen installation. Not all the pieces are there. We seem to be seeing that a lot this year. Try uninstalling it and reinstalling it with any antivirus disabled.
    central MO
    85
    Awesome. I will try and that get back
