Results 1 to 6 of 6
Thread: DMX18-DCSSR error state?
    Jul 2010
    Angier, NC
    20
    Question DMX16-DCSSR error state?
    So, I'm trying to use my DCSSR for the first time in forever to run my mighty-mini's (again - first time in forever).. Tried changing the start channel using the 'switchless' method.. and it doesn't appear to be working. When I plug in any kind of DMX controller, the RED LED goes solid, and nothing happens. I see no DMX activity. Have I cooked this thing?
    -Roger
    1,866
    Default Re: DMX18-DCSSR error state?
    I googled DMX18-DCSSR and basically came up blank. Do you have a link to some documentation? Is there a test mode on the controller?
    Jul 2010
    Angier, NC
    20
    Sorry meant DMX16 It's this guy here:
    http://www.doityourselfchristmas.com..._Completed.JPG
    -Roger
    Jul 2010
    Angier, NC
    20
    And documentation on it is pretty sparse. I've had to dig through the forums to find references to it, but I did read that it uses that 'switchless' method for changing the start channels. Beyond that, I have no idea. It did work at one point..
    -Roger
    Sep 2007
    Iowa
    471
    Jul 2010
    Angier, NC
    20
    Quote Originally Posted by Reddy_Kilowatt View Post
    Thanks Craig!
    I had read the first post you put up yesterday, but hadn't read the second one. But, I tried setting it using both Vixen and XLights, and it doesn't seem like it's wanting to talk DMX... I've tried 2 known good DMX devices to talk to the controller, and every time I connect the cable to the controller, all I get is a solid RED LED, and nothing else.
    -Roger
