Results 11 to 20 of 20
Thread: What Welder to get?
    Dec 2009
    WesternTreasure Valley, Idaho
    1,209
    Default Re: What Welder to get?
    I have the same welder that Doug P has only it is an older one. I have been using it for 6 years now and never reached duty cycle. Can't go wron gfor a hobby welder. Doug uses his probably 50 times more than I do now.
    Delafield,WI
    249
    I have one of those cheap HF welders. Yes it does spit some. But for under $100 it's a reasonable deal. I've found one of the important things to be aware of is you need to use a 20 amp circuit. Not that it will blow a breaker on a 15 amp outlet, the voltage drop on the line will have a big impact on your welds. I prefer to run it off my 3500 watt generator. A huge difference without the input voltage dropping.
    Apr 2017
    3
    Quote Originally Posted by Wolfie View Post
    First and foremost, I AM NOT A WELDER. I only have very little experience. But that experience is very much related to the OP's desire. Wireframes.
    I agree, the HF welder is crap. But its very very cheap crap that will work for at least part of what the OP is wanting to do. There are several tutorials on converting it from AC to DC and I plan on doing so this summer which appears to improve its performance considerably for minimal additional cost. However, out of the box it does work and can work for your needs, at least on the wireframe aspect. And it can do so on a very small budget. I used it to make this last year:
    It went on to become Serena's disco ball halloween costume.
    You are NOT going to weld aluminum with it. You are NOT going to weld structural steel with it. It will weld wire of most gauges we will likely be using for wireframes in our projects. It will weld thin mild steel (1/8" rated but I have done thicker though not pretty). It is NOT the best welder by any stretch of the imagination. It is the cheapest though Under a hundred clams and you can be making blinky stuff. And it runs on standard 115v. Many of the other welders folks above recommended require 230v. So if you don't have that in your garage/work area, then you are going to either have to stick with smaller cheaper 115v welders or you are gonna need to run a 230v circuit for the welder.
    If, and I repeat IF you can afford a better welder, then I would. The HF flux welder spits like a major league pitcher, mainly because its flux but also because its AC. DC conversions do seem to help with that according to everything I can see/read. I will likely find out this summer when I convert mine. At the time, I wasn't expecting to use it much after the disco ball project. I mostly considered it a cost of making the costume and mostly as a consumable and basically a throw away. However I have found it handy to have and used it for tweaking and fixing other odd projects around the house. Had I known I would end up kinda liking welding and have any further use of it, I probably would have opted for one of the Eastwoods. I am not sorry I got the HF cheapie flux welder. IIRC, I think I got it for around $80 on sale with a coupon and considered it a disposable tool. It got the job done, it did more than I asked of it and welded stuff bigger than its rated for. I still have it and will still use it.
    Welding wire was, well, how can I say this. Um. A PITA. Never having welded before, took no lessons, and had no tutor or mentor made it a challenge. There is so little room for error before you burn the wire and thats a hard lesson to learn too. Welding flat stock and hardware was a piece of cake compared to thin wire. So prepare yourself for some initial frustrations getting your first wireframes done. Consider them practice pieces. And, if you know a welder, see if you can pick his(her) brain or get a mentor. Wish I had one.
    Eastwood is a good option. Before that, what I think is you need to be good at welding. If you are hobbyist definitely you need to know the basic welding. Go with the vast and vivid google. Youtube is my best teacher but when it comes to the practical session it lacks. I have experience. I started welding with the help of youtube, I surfed for the welding videos, tips, safety measures while doing the welding from there. It is really helpful for small welding works but when it comes to professional it lacks. Mainly because it is difficult to clear our doubts. So, the better option is to go for regular courses. There are many welding programs are available like 4 days tool and die courses. Better you choose such welding programs or night classes and get trained in it.
    May 2018
    Iowa,Des Moines
    1
    Miller, Hobart, and Lincoln make portable welders with that much auxiliary power in a few models of each brand. Some won't have all the welding capabilities for TIG or MIG but those that cost a bit more will. That is what they were built for to supply more auxiliary power at job sites yet also be able to put out more on 220V auxiliary for emergencies. Also, before I forget, I would like to know. Are there any gambling enthusiasts amongst you? What do you think about online casino reviews? Recently, I found a great page about reviews here - /reviews/. How do you feel about all kinds of casino reviews on the internet?
    7
    Thanks for all the advice in this thread. I'm not sure I can clear enough space in my garage to weld without catching stuff on fire. What kind of welder would you recommend for welding wireframes in the back yard?
    Dec 2009
    1,209
    If you are going to do tig I would get this one. Does mig, tig and stick. I had great luck with the Vulcan. 1 year risk free money back guarantee. Can't go wrong trying it. They will stand behind the risk free. https://www.harborfreight.com/protig...put-63619.html
    Colorado Springs
    3,898
    I would still opt for the Eastwood MIG Welder...........
    Southern California
    1,209
    Bought this one from Home Depot. My understanding is that this brand is owned by Lincoln. Don't know if that makes it any better. But it only weighs 17 pounds and runs off 120vac. I was able to weld some thin wall square tubing to repair a gate. i also made some brackets and guides for a barn door for my shed. Ihad never welded before. I bought the auto darkening helmet from Harbor Freight.
    https://www.homedepot.com/p/Century-...93-1/302139495
    Kevin
  9. #19
    7
    Thanks for all the advice. Can I weld in my garage? I have a metal work table, but it is in the corner right up against the walls (exposed studs). How much space around the part should I have for MIG?
  10. #20
    Jun 2021
    1
    I welded the wire with copper-phosphorus solder for copper + borax powder. I used a propane-oxygen torch for heating. First, we need to remove the rust from the wire. We take a rod of solder, slightly heat its tip in the burner's flame, and dip it in the borax powder. The borax will stick to the solder. We heat the wire until it is red and put the solder into the soldering point. It will melt and solder the surfaces. The borax serves as flux. Of course, you need practice. Try practicing on pieces of copper tubing that are used for heating and cooling systems. If you want to know how you can become a welder, you can look at this site.
