Results 1 to 10 of 22
Thread: Need Help With Helix Ether-Node
    Jan 2014
    87
    Default Need Help With Helix Ether-Node
    I'm working on integrating the Ether-Node along with an E6804 into the Helix system.
    For some reason the Ether-Node is not linking with the E6804.
    So far, I've set the IP on the E6804 to 192.168.10.11. The term jumper for RS-485 comm is set on both the main network controller and the ether-node (3rd and last ID; I have a main board (ID 2) in the middle, the term jumper removed).
    I can access the E6804 web page from my laptop, but the Ether-node does not appear to link with it. I've tested my network cables and they're good.
    I've also verified I have the correct SD cards are in the correct controllers with their files.
    The Ether-Node is showing it has a connection to the network.
    I've added the ether-node in HNS 3.2 and setup the E6804 as 192.168.10.11 for the config.
    I'm not sure what I'm missing.
    Is there any more testing someone can suggest I do to troubleshoot?
    I've been thinking of trying to play a short sequence from my laptop, through the E6804. That would be tonight. But, not sure what I can do to test the Ether-node controller.
    Jan 2014
    87
    Default Re: Need Help With Helix Ether-Node
    Last night, I noticed the heartbeat LED on the Ether-Node is not blinking. But, the Wired RX LED flashes.
    Anyone run into this?
    Jan 2014
    87
    My E6804 config
    Jan 2014
    87
    Helix Network Controller
    Jan 2014
    87
    Helix Network Node
    Jan 2014
    87
    Ether-Node
    Jan 2014
    87
    Schedule
    Claremore, OK
    188
    I just pulled up my old helix configs. Yours looks identical to mine. I never had an issue. I don't remember if the ethernode would flash or not. I haven't used in 3 years. .
    Jan 2014
    87
    Hi MLevings,
    I've read many posts where you were involved. Glad to hear from you. Thanks for your efforts.
    I heard from Greg by email. It's an exam week for him. I'm hoping to hear from him again soon, when he is done with his exam.
    I just changed my configs this morning to what I posted and tested with it. Same deal. I didn't previously do the DMX universes correctly. I realized it after looking at Greg's Ether-Node posting, a few times...
    I'm glad you confirm that I now have it correct. Whew.
    So, I know something must not be right with the Ether-Node board.
    I have to jumpstart it to get it working (multimeter on ohms going between R4-3.3V and the 3.3V lead at the SD Card slot). I found out how by accident. I was checking continuity across the board and one time I powered it up, I got Heartbeat.
    So, once I get it going, I am able to ping the board's IP address. I even get activity at the SanDevice (E6804) pixel controller's universes, as if the Ether-Node is sending comm to the E6804. But, no LINK light on the Ether-Node for the socket. The Socket (1) Enabled light turns on, as it should. And not pixel lights lighting up. With the test pattern, if enabled on the E6804, does work. Lights do work.
    Jan 2014
    87
    Showing packets received after running the triggered show.
