Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Coro question
    Taylor, Michigan
    831
    Default Re: Coro question
    Quote Originally Posted by jleiwig View Post
    White. If you've ever seen reusable boxes in stores they are usually made of clear, which looks translucent but murky if that makes sense
    Sent from my NookColor using Tapatalk
    Ok gotcha. Thanks!
    2012: First year, 104 renard channels
    2013: 280 Renard Channels, 1050 Pixel Channels (2 x E6804)
    2014: Going pixel crazy!
    [URL="www.strotherfamilychristmas.com"]www.strotherfamilychristmas.com[/URL]
    Dec 2020
    109
    I must be missing something. Why should it not be opaque? You show the prop with the pixels' LED facing towards the street, I assume. So then it shouldn't matter. Or will the pixels still be partially inside the coro? If so and if you have purchased from HomeDepot.com, which one did you get?
    Edit: Actually, I have to rethink Home Depot. I just checked and the 10mm is $163 for a 3-pack of 4' x 8'. That's like $54/sheet
    Dec 2020
    21
    Ok, I'm new here, what would you do with a 4x8 sheet of coro?
    Mar 2020
    Post falls, Idaho, USA
    77
    Build props and add lights to it.
    Chambersburg, PA
    964
    Quote Originally Posted by dad311 View Post
    You can cut out any number of different props and drill them to accept the lights of your choice. I have made Candy Canes, Tree Top Stars, and Swinging Bells using Coro I have purchased.
    Topper Starv2 Model (1).pdf
    Swinging Bells break out.pdf
    Coro sheets are lightweight, strong, and durable.
    2016 - No Display
    Dec 2020
    109
    @TomL8345 what thickness of coro do you use? 4mm, 10mm? From some videos I saw the 4mm seem kind of flimsy, especially when fully exposed to the elements (wind). And where do you buy it? At Home Depot 4mm is like $20 a sheet and 10mm is $54.
    Chambersburg, PA
    964
    I used 4mm for my projects. I purchased several sheets a few years ago from a local Sign Shop, I do not remember what I paid. The candy canes were my own versions of the ones from Holiday Coro. The Topper Stars have a Wire Frame Star that I use to support them from behind. while the Swinging Bells have a piece of 1/2" PVC across the top and bottom and are hung from my house.
    2016 - No Display
