Upgrading HLS
Standard Upgrade
- Simply download the latest version, unzip the files, and overwrite the old files with the new ones.
Upgrade Path for Skipped Updates
- Upgrading from a version less than 11E: Install version 11H [1]
- Open any sequence you wish to keep in version 11H and Save Sequences.
- Upgrade from 11H to the most current version. [2]
- Open and Save sequences again to have them fully updated.
Download and Installation | Chapter 1: Getting HLS | Moving HLS Data Directories |
