Cliffiv said:I'm kinda new i can solder a board but I lack in lingo. The jumpers you are talking about are they from holes drilled through the board and soldered?
CJA
That version was one of the first ones I did so they could be made for testing, and is the easiest to home etch. I bring power in on the RJ45. The power led is an option I didn't use at the time. Jumper?jmelvin said:Wayne I noticed your schematic does not have the LED, power in plug and jumper as in the coop board.
http://www.doityourselfchristmas.com/forum/album_pic.php?pic_id=17
P.S. an FYI, the link on the "Start here if new to the grinch" page does not work any more.
This link takes one to the newer version of the Grinch, it has the 'v10' in the
file name (grinch_controller_construction_notes_v10_490.pdf ) where the pdf
print I downloaded does not. The first part of that link talks about a first board:
"This was the first board made and using the GRINCH V1.0 PCB." and this what
I think I have.
Are there any assembly instructions (or a hi-def pic.) for this older version?
Thanks a million again for helping!
Wayne...
Do you have that Home-Etch Grinch file available in ExpressPCB format? If so, may I have a copy?
Thanks,
Tom
Sorry to be a bother but I got a good etch on my board and
hate to waste my work. Also I'm not sure I could do a two
sided board, I made enough mistakes doing just the first
one. If I went with the newer version it would not be a
"home etch" I would need to find someone who makes the
board, in the U.S., and buy it.
Thank you so much for all of your help and input.
