Results 1 to 10 of 28
Thread: Noob, not getting it done
    Nov 2010
    52
    Default Noob, not getting it done
    Running xlights and trying to get controller set up so i can test some props. Hot 1st controller configured and think I have receiver that's long range connected. I've followed videos on how to set it up. When I try to test lights, nothing. My controller status light in xlights is red so assuming nothing is getting sent to controller. Any help greatly appreciated. Little overwhelmed. Just want some lights to turn on.
    May 2016
    394
    Default Re: Noob, not getting it done
    Which controller are you using? That’s the first thing we need to know.
    Nov 2010
    52
    Hinkspix pro with long range smart receiver.
    2,509
    What is the IP of the controller? What is the IP of the computer?
    Nov 2010
    52
    Controller is 192.168.0.62
    Computer is 192.168 1.1
    5,961
    And subnet masks for both?
    Nov 2010
    52
    255.255.255
    I just ran test mode on actual long range receiver manually. Lights tested. Just can't test on xlights or through hinks configuration page, so I'm missing something
    Nov 2010
    52
    My ethernet adapter on computer is 192.168.0.50 if that matters
    Nov 2010
    52
    I've been told my controller ip is wrong
    5,961
    One of the two IP addresses is wrong - the first 3 fields should be the same if the subnet mask is 255.255.255.0 (both should be 192.168.1.xxx or both should be 192.168.0.xxx).
