Results 1 to 7 of 7
Thread: Cat5e and 120 volts
    Kansas City Missouri
    2,107
    Default Cat5e and 120 volts
    I'm planning to run cat5e and 120 to outlets about 15 feet from the house. Can I run the 120 and cat5e inside the same conduit?
    6,012
    Default Re: Cat5e and 120 volts
    Noise will be significant .
    Folsom, CA, USA
    1,957
    Cat5e is typically rated 300V so yes, they can be run togeather.......but I would never do that for safety reasons. If there is a short you could send 120V thru your cat5e, taking out your network and anything connected to it. Majic s moke all over the place.
    15 feet is a short distant, run 2 conduits. And if noise is an issue, put 120V in EMT with waterproof connectors....
    In Lights Therapy
    2,107
    I'm just doing it to remove the unsightly boxes on the front if the house. I can use the gray pvc for running the lines because it's only going under mulch. I ran gray pvc from the house to the shed which is about 30 feet for electric and it's buried only 6 inches in the ground. It's held up for almost 15 years.
    Jan 2010
    Mims, Fl
    686
    Just curious, are you putting out temporary outlets in the yard for Christmas lights? Just curious, i have been tossing the idea around.
    2,107
    Quote Originally Posted by ben&bobbi View Post
    Yes, for Christmas lights and the outlets will be permanent. I will also utilize the outlets for 2 pond pumps I have running in the summer.
    1,172
    I have had a direct burial cable in my front yard from before I bought the house 25 years ago. I had to replace the plug last year (it plugs into a ground fault circuit on the porch). Works well and is more than adequate for that part of the display.
