Results 1 to 4 of 4
Thread: Esp32
    Jul 2013
    116
    Default Esp32
    Anybody using the ESP32 in their setup? I just got a few in and they work great at receiving E1.31. FastLED also supports it now if you want to drive pixels directly.
    Nov 2018
    4
    Default Re: Esp32
    Dear Sir, would you mind sharing the code for me try out E1.31 and to drive pixels.
    May 2016
    254
    Default Re: Esp32
    There are several different projects you can copy. The following is a e1.31 receiver using the esp8266: https://www.hackster.io/jasonspiva/e...troller-002072
    The ESP32 will run the same code provided that it is flashed to the Arduino IDE. Shelby Merrick (forkineye) and Bill Porter also have published their libraries and code that are used in the ESPixel line of controllers. Look for their stuff on github.
    Nov 2018
    4
    Default Re: Esp32
    Thank you Mr.Kensington, I am already using Jasonspiva's ESP8266 multiplexing Pixel controller and it works fine. But when I compile the same code for ESP32, it gives lot of compiling error as ESP32's library's are different, it seems. Please try it yourself and help me with a solution. Thanks in advance.
