Results 1 to 10 of 21
Thread: Sequence Locks Up
    Colorado Springs
    3,713
    Default Sequence Locks Up
    Several times recently when I have been working on a new sequence, the sequence will lock up as I am trying to stop it. I start a sequence with F6, play only a few notes, and stop it with F8, and sometimes get a popup that says "event thread did not terminate in time". The only way to clear it is to close Vixen. Am I doing something wrong?
    Oct 2007
    Bundanoon NSW Australia
    265
    Default Re: Sequence Locks Up
    Hi,
    I am getting the same problem but my issues are USB related. I have a USB-RS485 converter which is one of a number of devices plugged into a USB hub. I have not tracked it down yet but something connected to the USB hub is disconnecting and reconnecting (It gives the ding dong sound when it does). If I am running a vixen sequence at the time, it gives that same error message when I next stop the sequence.
    Craig
    Spokane, WA, USA
    685
    Is it only that new sequence? Any difference in the plugins you're using for that one as opposed to previous sequences?
    Colorado Springs
    3,713
    This is the first sequence I have begun working on in earnest. In the beginning it ran fine, but I have been experimenting with different add-ins, and using the audio visualizer, and then it began to lock up. I just tried another sequence from scratch, and added a bunch of random stuff, including the waveform addin, and the audio visualizer and it isn't locking up. Don't know what's up with the first one............
    Spokane, WA, USA
    685
    If it's just that one sequence, I'd be happy to take a look at it and see if I can make it happen over here. Maybe it's highlighting a hidden bug.
    Colorado Springs
    3,713
    Just started getting another error when I hit F6 to start the sequence (same one). Things were working O.k., and then all of a sudden every time I hit F6 I get a "Vixen" popup that says: [Renard Dimmer (Modified)
    Acces to Port "Com3" is Denied.]
    When I clear the error message, the sequence starts playing, but the message comes up every time I hit F6 now.
    More testing, it comes up on F5 or F6, and on every sequence I try.
    Rebooted computer and whatever that was went away. Vixen is operating correctly again.
    WI
    2,611
    KC I'm seeing the same issue here. Any time I stop a sequence the app locks. I'm using old sequences (older 2.x) and a USB to RS485 adapter (Open DMX clone). The issue seems to be serial port related.
    Melbourne , Australia
    896
    Dynamo can you check your CPU usage when the sequence stops.
    this sounds like the issue i am having as well. I can use the program and then once youtry and stop the sequence or the test suite the program locks and the cpu is sitting at 100%.
    About to head to work. Might try and take my adaptor to work and test it there quickly using the new version of vixen.
    Peter
    WI
    2,611
    Not 100% for me (51% on one CPU). This is pretty typical when you get an app lock.
    896
    still seems very similar to the issue im having.
    also i noticed i can get the same problem if i just start up a profile. leave the sequence blank and go into the channel test app. i can test the channels for as long as i want but when i go to leave the channel test it locks up as well.
    have you guys tried the channel test to see if it does the same?
    Peter
