Page 138 of 138 FirstFirst ... 3888128136137138
Results 1,371 to 1,379 of 1379
Thread: Home Brew Lighting System - Arduino Mega - SainSmart 16 Channel Relay Board
  1. #1371
    ottawa ks
    252
    Default Re: Home Brew Lighting System - Arduino Mega - SainSmart 16 Channel Relay Board
    ok in the new controller do I put 32 elements or when I map it will do right a way. is the map in the setup??? it is snowing here and 17 deg. coold
  2. #1372
    ottawa ks
    252
    in my controller the elements are connected but I can not get the controler to connect to the elements it shows 0 pached to controller. what am I doing wrong thanks
  3. #1373
    Southern California
    639
    Quote Originally Posted by johnboy View Post
    if you have 32 new elememnt, set things up the same way that you did for the first 32 except for the controller port.
    Kevin
  4. #1374
    Southern California
    639
    if you can't get it figured out in a couple of days, give me a call later in the week.
    Kevin
  5. #1375
    central MO
    59
    if I put vixon 3.0.6 in will it wright over 2.1.1.0 or do I have to take 2.1 out and start over I thank 2.1 is vixen 2 not sure on that . What do you think
    No. I have had vixen 2 and vixen 3 on same computer but I much prefer 3.
    Sent from my SM-G955U using Tapatalk
  6. #1376
    central MO
    59
    am doing well. can I use the mega no.2 and use the same song. not sure on how to add a mega to my system thanks
    Name your first mega as Mega 1 and 2nd Mega2 or however you wish to name. When patching. Take the elements you wish to have on mega 1 and patch to it. Same goes for mega number 2. It's best and easier all around to keep them organized. Such as 1-32 patched to mega1....and 33-64 to mega 2. I personally do use 2 megas. One for relays and one for pixels, tho I do not send data via serial. I route streaming e1.31.
  7. #1377
    ottawa ks
    252
    will do one more cold beer
  8. #1378
    ottawa ks
    252
    kev thanks for the help I do use the same sketch in controller 1 and 2?. got to bild a zero cross one more time. Thanks one more time talk later.
  9. #1379
    Southern California
    639
    Yes, use the same sketch. It was good to talk to you too. We got a little cold weather here today. It only made it up to 64....
    Kevin
