Uploads by Ravinglunatic
File list
First pagePrevious pageNext pageLast page
Date Name Thumbnail Size Description Versions
04:33, 6 August 2013 Wiki - Renard SS24 Board Assembly.pdf (file) 513 KB   2
04:33, 6 August 2013 Wiki - Renard SS24 Board Assembly (doc file).zip (file) 715 KB   2
04:32, 6 August 2013 Wiki - Renard SS16 Assembly.pdf (file) 554 KB   2
04:31, 6 August 2013 Wiki - Renard SS16 Assembly (doc file).zip (file) 864 KB   2
04:30, 6 August 2013 Wiki - Renard SS8 Assembly.pdf (file) 519 KB   2
04:29, 6 August 2013 Wiki - Renard SS8 Assembly (doc file).zip (file) 805 KB   2
21:09, 30 June 2013 Wiki - IC socket 1-14.jpg (file) 25 KB   1
02:19, 9 March 2013 ChristmasWiki Organization.jpg (file) 231 KB   3
06:18, 3 December 2011 Renard SS Diagnostic Firmware Instructions.pdf (file) 506 KB   1
06:12, 3 December 2011 Renard SS Operational Firmware.asm (file) 16 KB Operational firmware for the Renard SS boards. The same as the regular Renard firmware in file renard-20071229.asm except is defaulted to PWM. 1
06:06, 3 December 2011 Renard SS Diagnostic Firmware.asm (file) 10 KB Diagnostic Firmware for Renard SS boards. Same as regular Renard Beta Diagnostic Firmware. 1
03:11, 2 December 2011 PIC16F688 Pinout.jpg (file) 84 KB   1
04:20, 27 November 2011 Wiki - Renard SS Voltage Regulator to Heat Sink.jpg (file) 26 KB   1
04:02, 27 November 2011 Wiki - Renard SS Voltage Regulator to Heat Sink.gif (file) 40 KB   1
02:32, 27 November 2011 Renard SS8 Schematic.pdf (file) 72 KB Corrected mis-marked component 3
02:31, 27 November 2011 Renard SS16 Schematic.pdf (file) 106 KB Corrected mis-marked component 2
02:30, 27 November 2011 Renard SS24 Schematic.pdf (file) 141 KB   3
23:04, 10 October 2011 Renard SS Heat Sink Pattern.jpg (file) 22 KB   1
02:25, 7 March 2011 Vantec USB to RS232 Converter.JPG (file) 139 KB   1
02:24, 7 March 2011 TRENDnet USB to RS232 Converter.JPG (file) 159 KB   1
02:50, 27 February 2011 USB-RS232-RS485-RJ45.JPG (file) 66 KB   1
02:50, 27 February 2011 USB-RS232-RJ45.JPG (file) 77 KB   1
02:49, 27 February 2011 USB to RS485 Converter.JPG (file) 158 KB   1
02:49, 27 February 2011 USB to RS232 Converter.JPG (file) 123 KB   1
02:49, 27 February 2011 USB to RS232 Converter with RS485.JPG (file) 84 KB   1
02:49, 27 February 2011 Unitek USB to RS232 Converter.JPG (file) 246 KB   1
02:48, 27 February 2011 Sintech RS232 to RS485 converter.JPG (file) 102 KB   1
02:48, 27 February 2011 RS485 modded DE9-R45 adapter.JPG (file) 111 KB   1
02:48, 27 February 2011 RS232 to RS485 converter V1.JPG (file) 101 KB   1
02:48, 27 February 2011 RS232 to RS485 converter to RJ45.JPG (file) 76 KB   1
02:47, 27 February 2011 RS232 to RS485 converter (wired) V1.JPG (file) 98 KB   1
02:47, 27 February 2011 RS232 modded DE9-R45 adapter.jpg (file) 139 KB   1
02:46, 27 February 2011 HXSP-2108F USB to RS485 Converter.JPG (file) 135 KB   1
02:46, 27 February 2011 HXSP-2108F USB to RS485 Converter to RJ45.JPG (file) 79 KB   1
02:46, 27 February 2011 HXSP-2108F USB to RS485 Converter (wired).JPG (file) 97 KB   1
02:46, 27 February 2011 Hexin RS232 to RS485 V2 (wired).JPG (file) 127 KB   1
02:45, 27 February 2011 Hexin RS232 to RS485 converter.jpg (file) 166 KB   1
02:45, 27 February 2011 Hexin RS232 to RS485 converter V2.jpg (file) 256 KB   1
02:45, 27 February 2011 Hexin RS232 to RS485 (wired).JPG (file) 90 KB   1
02:44, 27 February 2011 DE9 to RJ45 Adapter.JPG (file) 128 KB   1
03:41, 21 February 2011 Renard channel limit.png (file) 105 KB   2
17:00, 17 February 2011 DMX16SSR PCBOARD.JPG (file) 101 KB   2
16:58, 17 February 2011 DMX4SSR.jpg (file) 124 KB   4
14:14, 15 February 2011 Wiki - Serial to Renard RJ45 Connection.jpg (file) 55 KB   1
14:13, 15 February 2011 Wiki - Serial to Renard DE9 Connection.jpg (file) 54 KB   1
14:13, 15 February 2011 Wiki - RS485 to Renard Connection.jpg (file) 52 KB   1
14:13, 15 February 2011 Wiki - DMX (XLR) to Renard Connection.jpg (file) 48 KB   1
14:12, 15 February 2011 Wiki - DMX (RJ-45) to Renard Connection.jpg (file) 47 KB   1
05:42, 15 February 2011 Wiki - Renard to Renard Data Cable.jpg (file) 56 KB   1
05:42, 15 February 2011 Wiki - Renard SS RS232 Data Cable2.jpg (file) 58 KB   2
