Uploads by Ravinglunatic
| 04:33, 6 August 2013 | Wiki - Renard SS24 Board Assembly.pdf (file) | 513 KB | 2 | ||
| 04:33, 6 August 2013 | Wiki - Renard SS24 Board Assembly (doc file).zip (file) | 715 KB | 2 | ||
| 04:32, 6 August 2013 | Wiki - Renard SS16 Assembly.pdf (file) | 554 KB | 2 | ||
| 04:31, 6 August 2013 | Wiki - Renard SS16 Assembly (doc file).zip (file) | 864 KB | 2 | ||
| 04:30, 6 August 2013 | Wiki - Renard SS8 Assembly.pdf (file) | 519 KB | 2 | ||
| 04:29, 6 August 2013 | Wiki - Renard SS8 Assembly (doc file).zip (file) | 805 KB | 2 | ||
| 21:09, 30 June 2013 | Wiki - IC socket 1-14.jpg (file) | 25 KB | 1 | ||
| 02:19, 9 March 2013 | ChristmasWiki Organization.jpg (file) | 231 KB | 3 | ||
| 06:18, 3 December 2011 | Renard SS Diagnostic Firmware Instructions.pdf (file) | 506 KB | 1 | ||
| 06:12, 3 December 2011 | Renard SS Operational Firmware.asm (file) | 16 KB | Operational firmware for the Renard SS boards. The same as the regular Renard firmware in file renard-20071229.asm except is defaulted to PWM. | 1 | |
| 06:06, 3 December 2011 | Renard SS Diagnostic Firmware.asm (file) | 10 KB | Diagnostic Firmware for Renard SS boards. Same as regular Renard Beta Diagnostic Firmware. | 1 | |
| 03:11, 2 December 2011 | PIC16F688 Pinout.jpg (file) | 84 KB | 1 | ||
| 04:20, 27 November 2011 | Wiki - Renard SS Voltage Regulator to Heat Sink.jpg (file) | 26 KB | 1 | ||
| 04:02, 27 November 2011 | Wiki - Renard SS Voltage Regulator to Heat Sink.gif (file) | 40 KB | 1 | ||
| 02:32, 27 November 2011 | Renard SS8 Schematic.pdf (file) | 72 KB | Corrected mis-marked component | 3 | |
| 02:31, 27 November 2011 | Renard SS16 Schematic.pdf (file) | 106 KB | Corrected mis-marked component | 2 | |
| 02:30, 27 November 2011 | Renard SS24 Schematic.pdf (file) | 141 KB | 3 | ||
| 23:04, 10 October 2011 | Renard SS Heat Sink Pattern.jpg (file) | 22 KB | 1 | ||
| 02:25, 7 March 2011 | Vantec USB to RS232 Converter.JPG (file) | 139 KB | 1 | ||
| 02:24, 7 March 2011 | TRENDnet USB to RS232 Converter.JPG (file) | 159 KB | 1 | ||
| 02:50, 27 February 2011 | USB-RS232-RS485-RJ45.JPG (file) | 66 KB | 1 | ||
| 02:50, 27 February 2011 | USB-RS232-RJ45.JPG (file) | 77 KB | 1 | ||
| 02:49, 27 February 2011 | USB to RS485 Converter.JPG (file) | 158 KB | 1 | ||
| 02:49, 27 February 2011 | USB to RS232 Converter.JPG (file) | 123 KB | 1 | ||
| 02:49, 27 February 2011 | USB to RS232 Converter with RS485.JPG (file) | 84 KB | 1 | ||
| 02:49, 27 February 2011 | Unitek USB to RS232 Converter.JPG (file) | 246 KB | 1 | ||
| 02:48, 27 February 2011 | Sintech RS232 to RS485 converter.JPG (file) | 102 KB | 1 | ||
| 02:48, 27 February 2011 | RS485 modded DE9-R45 adapter.JPG (file) | 111 KB | 1 | ||
| 02:48, 27 February 2011 | RS232 to RS485 converter V1.JPG (file) | 101 KB | 1 | ||
| 02:48, 27 February 2011 | RS232 to RS485 converter to RJ45.JPG (file) | 76 KB | 1 | ||
| 02:47, 27 February 2011 | RS232 to RS485 converter (wired) V1.JPG (file) | 98 KB | 1 | ||
| 02:47, 27 February 2011 | RS232 modded DE9-R45 adapter.jpg (file) | 139 KB | 1 | ||
| 02:46, 27 February 2011 | HXSP-2108F USB to RS485 Converter.JPG (file) | 135 KB | 1 | ||
| 02:46, 27 February 2011 | HXSP-2108F USB to RS485 Converter to RJ45.JPG (file) | 79 KB | 1 | ||
| 02:46, 27 February 2011 | HXSP-2108F USB to RS485 Converter (wired).JPG (file) | 97 KB | 1 | ||
| 02:46, 27 February 2011 | Hexin RS232 to RS485 V2 (wired).JPG (file) | 127 KB | 1 | ||
| 02:45, 27 February 2011 | Hexin RS232 to RS485 converter.jpg (file) | 166 KB | 1 | ||
| 02:45, 27 February 2011 | Hexin RS232 to RS485 converter V2.jpg (file) | 256 KB | 1 | ||
| 02:45, 27 February 2011 | Hexin RS232 to RS485 (wired).JPG (file) | 90 KB | 1 | ||
| 02:44, 27 February 2011 | DE9 to RJ45 Adapter.JPG (file) | 128 KB | 1 | ||
| 03:41, 21 February 2011 | Renard channel limit.png (file) | 105 KB | 2 | ||
| 17:00, 17 February 2011 | DMX16SSR PCBOARD.JPG (file) | 101 KB | 2 | ||
| 16:58, 17 February 2011 | DMX4SSR.jpg (file) | 124 KB | 4 | ||
| 14:14, 15 February 2011 | Wiki - Serial to Renard RJ45 Connection.jpg (file) | 55 KB | 1 | ||
| 14:13, 15 February 2011 | Wiki - Serial to Renard DE9 Connection.jpg (file) | 54 KB | 1 | ||
| 14:13, 15 February 2011 | Wiki - RS485 to Renard Connection.jpg (file) | 52 KB | 1 | ||
| 14:13, 15 February 2011 | Wiki - DMX (XLR) to Renard Connection.jpg (file) | 48 KB | 1 | ||
| 14:12, 15 February 2011 | Wiki - DMX (RJ-45) to Renard Connection.jpg (file) | 47 KB | 1 | ||
| 05:42, 15 February 2011 | Wiki - Renard to Renard Data Cable.jpg (file) | 56 KB | 1 | ||
| 05:42, 15 February 2011 | Wiki - Renard SS RS232 Data Cable2.jpg (file) | 58 KB | 2 |
