Uploads by Phil Short
| 19:22, 6 June 2013 | Renard-px1 RevE.PNG (file) | 33 KB | 1 | ||
| 16:16, 6 June 2013 | Renard-px1 RevE sch.PNG (file) | 33 KB | 1 | ||
| 18:08, 2 November 2011 | LEDancer-20111101.asm (file) | 18 KB | 1 | ||
| 18:02, 2 November 2011 | LEDancer-revA.png (file) | 18 KB | 1 | ||
| 17:53, 2 November 2011 | LEDancer2.PNG (file) | 35 KB | 1 | ||
| 19:28, 27 May 2011 | LEDancer1.png (file) | 33 KB | 1 | ||
| 19:13, 27 May 2011 | LEDancer PCB Example1.png (file) | 13 KB | 1 | ||
| 18:22, 27 May 2011 | Ledancer-20110527.asm (file) | 17 KB | 2 | ||
| 18:19, 27 May 2011 | LEDancer-20110527.asm (file) | 17 KB | 1 | ||
| 15:33, 22 May 2011 | LEDancer-20110522.asm (file) | 15 KB | 1 | ||
| 15:14, 22 May 2011 | LEDancer-20110521.asm (file) | 15 KB | 1 | ||
| 05:02, 22 May 2011 | LEDancer LED SCH.png (file) | 25 KB | 1 | ||
| 04:59, 22 May 2011 | LEDancer LED SCH.PNG (file) | 25 KB | 1 | ||
| 04:49, 22 May 2011 | LEDancer.PNG (file) | 33 KB | 2 | ||
| 04:34, 22 May 2011 | LEDancer PCB Example.png (file) | 13 KB | 2 | ||
| 04:15, 22 May 2011 | LEDancer LED Module.PNG (file) | 8 KB | 1 | ||
| 04:08, 22 May 2011 | LEDancer.png (file) | 32 KB | 1 | ||
| 21:20, 9 January 2008 | Renard64 xc.pdf (file) | 103 KB | XC rev schematic, as the board went out for proto. Schematic manually created after the fact, so take it with a grain of salt. | 1 | |
| 21:18, 9 January 2008 | Renard64 xc5b.gif (file) | 48 KB | PCB as it went out for proto. | 1 | |
| 21:07, 8 December 2007 | Grinch pcb assembled.jpg (file) | 67 KB | 1 | ||
| 01:26, 24 October 2007 | Renard-20071023.asm (file) | 17 KB | Beta test code...changes in attempt to reduce flickering at low dimmer levels with LED strings. | 1 | |
| 04:03, 12 October 2007 | Renard64 sch 002.pdf (file) | 105 KB | 2 | ||
| 03:24, 31 August 2007 | Ren-diag-20060905.asm (file) | 8 KB | 1 | ||
| 00:19, 29 August 2007 | Renard64 layout XB.gif (file) | 42 KB | 1 | ||
| 23:54, 18 August 2007 | Ren-diag-20070815a.asm (file) | 8 KB | Renard diagnostics firmware - uses external 18.432 MHz oscillator | 1 | |
| 21:19, 17 August 2007 | Xformer ct.gif (file) | 3 KB | Revised Drawing - center-tapped transformer with rectifier | 1 | |
| 21:07, 17 August 2007 | Xformer conn2.gif (file) | 53 KB | Transformer Connections using a center-tapped transformer | 1 | |
| 21:07, 17 August 2007 | Xformer conn1.gif (file) | 53 KB | Connections when using regular transformer | 1 | |
| 20:37, 17 August 2007 | Sinewave rect.gif (file) | 725 bytes | Unlabelled rectified sine waveform (abs(sin(wt)) | 1 | |
| 20:36, 17 August 2007 | Sinewave nolabel.gif (file) | 733 bytes | Unlabelled Sine Waveform | 1 | |
| 20:26, 17 August 2007 | Xformer ct.GIF (file) | 3 KB | Schematic of a center-tapped schematic with a two-diode full-wave rectifier | 1 | |
| 20:25, 17 August 2007 | Xformer regular.GIF (file) | 3 KB | Schematic of a simple transformer with a full-wave bridge rectifier | 1 | |
| 17:28, 30 June 2007 | Renard64 sch 001.pdf (file) | 105 KB | Schematic for Renard64 - document the board as it is now. | 1 | |
| 03:18, 30 June 2007 | Transformer pcb sch 002.GIF (file) | 9 KB | 2 | ||
| 15:45, 29 June 2007 | Renard8-20070228b.gif (file) | 24 KB | Screen capture of PCB layout. | 1 | |
| 15:42, 29 June 2007 | Renard8 XA sch a.GIF (file) | 21 KB | Updated schematic for first Rev PCB | 1 | |
| 15:20, 29 June 2007 | Renard8 XA sch.GIF (file) | 19 KB | Schematic for first revision of Renard8 PCB | 1 | |
| 18:30, 28 June 2007 | Transformer pcb sch 001.GIF (file) | 20 KB | One possible PC-Renard Interface, using RS232. Pinout is for Xmus Board, Renard64, Ren-C and future Renard8. | 1 | |
| 23:43, 23 June 2007 | Dimmer waveforms 001.gif (file) | 2 KB | Some dimmer waveforms, needs editing to add labels | 1 | |
| 20:27, 23 June 2007 | Renard8 img 001.jpg (file) | 17 KB | Somewhat poor image of an assembled renard8 pcb. | 1 | |
| 16:40, 23 June 2007 | Renard generic sch.gif (file) | 11 KB | Generic Renard schematic, identical to the one currently on the cc.com how-to. | 1 |
