User contributions for Fkostyun
25 September 2009
- 18:5618:56, 25 September 2009 diff hist +101 Part Substitutions →Diodes, LEDs, Triacs
- 18:5418:54, 25 September 2009 diff hist +4 Part Substitutions →Voltage Regulators
- 18:5318:53, 25 September 2009 diff hist −61 Part Substitutions →Other
- 18:5318:53, 25 September 2009 diff hist +27 Part Substitutions →Voltage Regulators
- 18:4918:49, 25 September 2009 diff hist +100 Part Substitutions →Other
- 18:4018:40, 25 September 2009 diff hist +5 Part Substitutions →Other
- 18:3918:39, 25 September 2009 diff hist −13 Part Substitutions →Other
- 18:3918:39, 25 September 2009 diff hist +2 Part Substitutions →Other
- 18:3718:37, 25 September 2009 diff hist +11 Part Substitutions →Other
10 May 2009
- 20:1320:13, 10 May 2009 diff hist +125 24 Channel Renard with SSR Assembly Instructions Fixed up BOM some more - replaced outdated parts to new ROHS versions.
- 18:0218:02, 10 May 2009 diff hist +266 24 Channel Renard with SSR Assembly Instructions and a final spell check
- 17:3417:34, 10 May 2009 diff hist +486 24 Channel Renard with SSR Assembly Instructions Updated board info sheet, cleaned up BOM, removed older references to boards 2.5 & 3.0, corrected link to assy manual, added part coop info, added link to info site, and compiled firmware
- 17:0617:06, 10 May 2009 diff hist +34 24 Channel Renard with SSR Assembly Instructions No edit summary
- 16:5416:54, 10 May 2009 diff hist +1 24 Channel Renard with SSR Assembly Instructions →Co-Op Board 3.3 Assembly Instructions
- 16:5316:53, 10 May 2009 diff hist −2 24 Channel Renard with SSR Assembly Instructions →Co-Op Board 3.3 Assembly Instructions
31 March 2009
26 September 2008
- 15:5615:56, 26 September 2008 diff hist +86 24 Channel Renard with SSR Assembly Instructions →Design Notes for v 3.3 Co-Op Board
- 15:2415:24, 26 September 2008 diff hist −3 24 Channel Renard with SSR Assembly Instructions →COOP PCB V3.0
- 15:2315:23, 26 September 2008 diff hist 0 N File:26-72.jpg No edit summary current
- 14:2114:21, 26 September 2008 diff hist −1 24 Channel Renard with SSR Assembly Instructions →Co-Op Board 3.3 Assembly Instructions
- 14:2014:20, 26 September 2008 diff hist −153 24 Channel Renard with SSR Assembly Instructions →Co-Op Board 3.3 Assembly Instructions
6 September 2008
- 15:0315:03, 6 September 2008 diff hist +160 24 Channel Renard with SSR Assembly Instructions →BOM: update some part #'s due to discontinued items. changed dual stack screw down to 35 degree ones.
8 August 2008
- 18:0418:04, 8 August 2008 diff hist +105 Renard 24LV →BOM
- 17:5717:57, 8 August 2008 diff hist −125 Renard 24LV →Renard 24 Jumper Settings and Options
- 17:5617:56, 8 August 2008 diff hist +730 Renard 24LV No edit summary
- 03:5903:59, 8 August 2008 diff hist +81 24 Channel Renard with SSR Assembly Instructions →Renard 24 Jumper Settings and Options
- 03:3303:33, 8 August 2008 diff hist +106 24 Channel Renard with SSR Assembly Instructions →General Note
- 03:3103:31, 8 August 2008 diff hist +73 24 Channel Renard with SSR Assembly Instructions →Renard 24 Jumper Settings and Options
- 03:2903:29, 8 August 2008 diff hist −1 24 Channel Renard with SSR Assembly Instructions →Renard 24 Jumper Settings and Options
- 03:2903:29, 8 August 2008 diff hist +1 24 Channel Renard with SSR Assembly Instructions →Renard 24 Jumper Settings and Options
- 03:2403:24, 8 August 2008 diff hist −19 24 Channel Renard with SSR Assembly Instructions →Renard 24 Jumper Settings and Options
- 03:2103:21, 8 August 2008 diff hist 0 N File:120v240v.jpg No edit summary current
- 03:1003:10, 8 August 2008 diff hist +416 24 Channel Renard with SSR Assembly Instructions No edit summary
- 03:1003:10, 8 August 2008 diff hist 0 N File:Zc1.jpg No edit summary current
- 03:0903:09, 8 August 2008 diff hist 0 N File:Transformer.jpg No edit summary current
- 03:0803:08, 8 August 2008 diff hist 0 N File:240v.jpg No edit summary current
- 03:0803:08, 8 August 2008 diff hist 0 N File:120v.jpg No edit summary current
- 02:4202:42, 8 August 2008 diff hist 0 24 Channel Renard with SSR Assembly Instructions →COOP PCB V2.5
4 August 2008
- 17:5017:50, 4 August 2008 diff hist +28 24 Channel Renard with SSR Assembly Instructions →Renard 24 Jumper Settings and Options
- 17:4917:49, 4 August 2008 diff hist +472 24 Channel Renard with SSR Assembly Instructions No edit summary
- 17:3717:37, 4 August 2008 diff hist 0 24 Channel Renard with SSR Assembly Instructions →PC to Renard Cable
- 17:3617:36, 4 August 2008 diff hist +286 24 Channel Renard with SSR Assembly Instructions No edit summary
- 17:2217:22, 4 August 2008 diff hist +46 24 Channel Renard with SSR Assembly Instructions →Co-Op Board 3.3 Assembly Instructions
- 17:2117:21, 4 August 2008 diff hist +253 24 Channel Renard with SSR Assembly Instructions →Co-Op Board 3.3 Assembly Instructions
- 16:1016:10, 4 August 2008 diff hist +69 24 Channel Renard with SSR Assembly Instructions No edit summary
- 16:0816:08, 4 August 2008 diff hist +69 Renard 24LV No edit summary
- 16:0216:02, 4 August 2008 diff hist +197 Renard 24LV No edit summary
- 16:0016:00, 4 August 2008 diff hist +28 24 Channel Renard with SSR Assembly Instructions →Testing the v 3.3 Co-Op Board
- 15:5915:59, 4 August 2008 diff hist +188 24 Channel Renard with SSR Assembly Instructions No edit summary
3 August 2008
- 21:2821:28, 3 August 2008 diff hist +494 Renard 24LV →Usage Ideas
