What is the TIR Flood?
These are commercial RGB outdoor DMX floodlights designed and sold by TIR Systems Ltd..  They are Model Number: Destiny CG-WGO-RGB-CUS-V2  These lights were originally mounted on the Duke Energy Building and were replaced with other RGB fixtures.  DIYC member rfallatt arranged to buy over 300 lights from the building and offered them to users via a group buy in August 2012.  There was a mixture of working and bad units sold.  The bad units suffered from water entering either the control module or the power supply and shorting out the boards.  It appears that the water may have wicked up the inside of the power and data cords and caused the issues.  Some of the bad units had the glass face plate broken. TIR Systems (in Canada) were considered the leader in outdoor LED systems and were also popular with large dance halls. They were a public stock company until 2007 when Phillips purchased them. They appear to have shut down operations in late 2008.  The manufacture date on the units is late 2008, and based on information, they units were removed from service in 2010.
Manufacturer's Description
How does the TIR Flood work?
These are RGB flood lights that are controlled via DMX and possibly via an unidentified ethernet based protocol.  There is a 5 pin XLR DMX connector that comes configured for DMX input only.  Out of the box these units respond to DMX channels 1-3 (RGB) when powered up and connected to a signal source.  The address programming packets have been decoded and there are  several ways to program new DMX addresses into the units. These units will fall back to a test sequence if the DMX signal is not applied.  The test sequence is a series of color fades.  The units also come with a ethernet cable attached and the control protocol has not been established for using it.
Dimensions of the TIR Flood
TIR Flood Components
Connectors
The units come equipped with a 15A 125vAC 3 Pin Twistlock power plug, a RJ45 ethernet interface cable and a 5 PIN XLR DMX cable attached.  The power and DMX cable come out of the base of the mounting bracket thru the waterproof cable holders.  The ethernet cable is tucked inside the base of the mounting bracket and has a rubber waterproof sleeve on the end.
Housing
LED Assembly
The flood lights have 48 Luxeon LEDs mounted in a sealed module on the front of the unit.  There are 16 each of Red, Blue and Green.  The LEDs are mounted on two PCB boards. The LEDs are arranged in a 2x6 array for each color on the upper PCB and 1x4 on the lower PCB.  This video shows how to test the LED Assembly when removed from the housing.
Control Module
There is a control module that drives the LEDs and responds to the DMX commands provided to it thru the DMX interface. The Control Module is mounted inside a waterproof housing and is attached to the rear heatsink with a generous amount of heatsink compound.  Inside of the Control Module there a main control board with a Ethernet Module daughter board.  The ICs on the main control board are listed below.
| IC Location | Part Number | Description | Datasheet |
| Q1-Q15 | IRL510S | Power MOSFET | http://www.vishay.com/docs/90380/90380.pdf |
| U2 | LM2676 | (ACTIVE) SIMPLE SWITCHER High Efficiency 3A Step-Down Voltage Regulator | http://www.ti.com/lit/gpn/lm2676 |
| U3,U8,U12,U16 | HC4066 | QUADRUPLE BILATERAL ANALOG SWITCH | http://www.ti.com/lit/ds/symlink/sn74hc4066.pdf |
| U4 | LM1117 | 800mA Low-Dropout Linear Regulator | http://www.ti.com/lit/ds/symlink/lm1117-n.pdf |
| U5,U7,U9,U10 | LMH6644MA | 3V, Low Power, 130MHz, 75mA Rail-to-Rail Output Amplifiers | http://www.ti.com/lit/gpn/lmh6644 |
| U6 | LM2902D | QUADRUPLE OPERATIONAL AMPLIFIERS | http://www.ti.com/lit/ds/symlink/sn74lvc4245a.pdf |
| U11,U20 | LJ245A | OCTAL BUS TRANSCEIVER AND 3.3-V TO 5-V SHIFTER WITH 3-STATE OUTPUTS | http://www.ti.com/lit/ds/symlink/sn74lvc4245a.pdf |
| U13,U14,U15 | HC14 | HEX SCHMITT-TRIGGER INVERTERS | http://www.ti.com/lit/ds/symlink/sn74hc14.pdf |
| U18 | LD71D1048C | 10 bit PWM controller / 48 Channel Output LED DRIVER | http://www.ldt.co.kr/common/app_inc/download.asp?file_nm=/data/bbs_Display_Driver_IC_1/LD71D1048C.pdf |
| U21 | VP3085 | Low-Power RS-485 Transceivers | http://www.ti.com/lit/ds/symlink/sn65hvd3082e.pdf |
Ethernet Module
There is an  ethernet module mounted inside the control module.  It appears that this is the main processor for the lights.  The DMX address and serial number of lights are programmed into this unit.  The ethernet interface to this module has not been identified yet. Technical Information about the Netburner ethernet module.  The NetBurner module uses the ColdFire MCF5282 processor.  Using the Netburner IP program, one user got the following response "MOD5282 Unit: at 192.168.1.47 running :LuminaireFX (3081041) $Date: 2005/02/04 18:42:48 $, $Name: B_Dma6Aug2004_MainTest $".
Power Supply
The power supply is a 100-240 VAC input and 24.5VDC 3.3A output.  The power supply is sealed in a waterproof enclosure and the wires come through the enclosure via waterproof sealing glands.
The power supply has an input power cord on one end and has a red and black 16ga wire on the other end that connects to the control housing.  Midway between the power supply and the control housing there is black shrink wrap on the red and black power leads.  If you carefully remove the heat shrink, you will find blue "bullet" type connectors that can be separated by pulling them apart. With the power cord bullet connectors apart, you can them test the power supply output  to see if the power supply is working.  You can also apply a different 24vdc power supply to the control module to see if it is working.
Mounting Bracket
Disassembling the TIR Flood
Main Body Separation
- Remove the 3 screws with washers near the rounded back edge on both side panels near the bracket attachment.
Between the mounting plate and the enclosure is white thermal grease.  This grease makes quite the mess.
Instead, you can use Isoprophyl Alcohol.  Any Percent purity is fine. This is the stuff that is less than $1 a bottle and available at any drug store or pharmacy section like at WalMart.
It will dissolve the grease and is safe for contact with human skin!  Wear gloves when removing the units to keep the thermal grease off of you.
- Some of the units appear to have been repaired in the field and have large amounts of silicone caulking around the base of the modules. You will need to cut away the caulking with a sharp knife and pull the caulking out with pliers.
 - Loosen the four screws that hold the black plastic housing and base plate to the light housing. You may need to use pliers to remove the screws since they are held in place by heat sink compound. Wear gloves, there is a lot of thermal heat sink compound behind the base plate. Wedge a paint scraper or other thin object between the aluminum base plate on the module and the back housing. Gently pry them apart. The thermal heat sink compound holds the unit tightly in place, but it will pry apart if you have removed the 4 screws and any excess caulking that may be present.
 - Turn the module over and remove the 8 screws that hold the base plate to the black plastic housing.
- Firmly grasp one pin of the plug with a pliers.
 - Gently pull back on the rubber boot while pulling on the plug. It may help to stretch the edges of the boot to make it come out easier. The boot will slide back down the wire off the plug.
 - Unscrew three screws on the face of the plug and unscrew the two screws retaining the cord on the back of the plug.
 - Slide the assembly out and unscrew the three screws holding the wires in.
 - The wire color code is listed here.
TIR Flood Power Requirements
The units come equipped with a 15A 125vAC 3 Pin Twistlock power plug. At 100% brightness RGB the flood draws 78 watts @116.5vAC.
The internal power supply provides 24vdc @ 3.3A to the control electronics.  A quick test of the current draw for the LEDs and controller  shows that each color draws about 1.2A per color and a total of 2.8A for all three colors  when full on.
| Current (A) | Red (%) | Green(%) | Blue(%) |
| 0.08 | 0 | 0 | 0 |
| 1.17 | 100 | 0 | 0 |
| 1.17 | 0 | 100 | 0 |
| 1.17 | 0 | 0 | 100 |
| 2.24 | 100 | 100 | 0 |
| 2.24 | 0 | 100 | 100 |
| 2.24 | 100 | 0 | 100 |
| 2.78 | 100 | 100 | 100 |
AC Power Cable
| Conductor | Wire Color |
| Line | Brown |
| Neutral | Blue |
| Ground | Green/Yellow |
Controlling the TIR Flood
The flood comes equipped with a 5 pin XLR DMX connector. Only the  input wires are connected to the XLR connector, but the output wires are also available and they can be soldered to the plug.  The lights can be controlled by sending a DMX signal to the lights on channels 1-3 to control the RGB lights.  It is believed that these floods were controlled by a software package called LuminaireFX.  This is the Control software developed by TIR for this unit. It's a control system for their "TBus" option.
DMX Wire / XLR Connector
The data connection to the flood light is thru a 5 pin Male XLR DMX connector.  Only the input DMX lines are soldered to the plug.  The output wires are in the cable and are active.  The input and output wires connect together in the control module.  There is no DMX termination resistor on the  light.
| DMX IN Shield | Bare Wire in Red Foil | 1 |
| DMX OUT Shield | Bare Wire in Green Foil | NC |
| DMX OUT + | White Wire in Green Foil | NC |
A detailed schematic is not available.
There are two LED boards, the upper one with 36 LEDs and the lower one with 12 LEDs. The upper board consists of 2 circuits with 6 LEDs each for each color and the two circuits are powered thru the separate connectors. The lower board consists of 1 circuit with 4 LEDs for each color and has it's own power connector.
An analysis of the voltage and current draw of the LED circuit boards is here.
| LED Current | 0.20A | 0.25A | 0.30A | 0.35A |
| Top Array (6 LEDs) | ||||
| Red | 15.8V | 16.7V | 17.3V | 18.0V |
| Green | 17.6V | 18.0V | 18.3V | 18.7V |
| Blue | 19.5V | 19.9V | 20.2V | 20.5V |
| Middle Array (6 LEDs) | ||||
| Red | 15.8V | 16.5V | 17.3V | 17.9V |
| Green | 17.6V | 18.0V | 18.3V | 18.6V |
| Blue | 19.4V | 19.9V | 20.1V | 20.4V |
| Bottom Array (4 LEDs) | ||||
| Red | 12.2V | 13.3V | 14.3V | 15.3V |
| Green | 12.6V | 13.1V | 13.7V | 14.1V |
| Blue | 12.9V | 13.1V | 13.3V | 13.4V |
The following photos show the highlighted traces on the LED PCBs by LED color.
Internal Wiring Color Codes
Lower LED board J2 (4 LEDs per color)
| LED Connection | Wire Color | LEDs |
| Common (+) | Red/Green | D1 - D12 |
| RED | Red/Black | D5 - D8 |
| GREEN | White/Black | D1 - D4 |
| BLUE | Green/Black | D9 - D12 |
Upper section JP2
| Common (+) | Black/Red | LED7-12,LED19-24,LED31-36 |
| RED | White | LED19 - LED24 |
| GREEN | Black | LED7 - LED12 |
| BLUE | Red | LED31 - LED36 |
Lower section JP1
| Common (+) | Orange/Red | LED1-6,LED13-18,LED25-30 |
| RED | Orange | LED13 - LED18 |
| GREEN | Green | LED1 - LED6 |
| BLUE | Blue | LED25 - LED30 |
Thermistor
LED Connector
| Pin Number | Wire Color |
| 1 | White |
| 2 | Green |
| 3 | Blue |
| 4 | Red/Black |
| 5 | Orange/Black |
| 6 | Black/White |
| 7 | Green/White |
| 8 | Black/Red |
| 9 | Orange/Red |
| 10 | Red/Green |
| 11 | Black/Red/White |
| 12 | Red/Black/White |
| 13 | Black |
| 14 | Red |
| 15 | Orange |
| 16 | White/Black |
| 17 | Green/Black |
| 18 | Blue/Black |
| 19 | Red/White |
| 20 | Blue/White |
| 21 | White/Red |
| 22 | Blue/Red |
| 23 | Thermistor \ |
Replacement Power Supplies
Replacement Control Modules
Non-OEM replacement for the Control Module options include a DCSSR driven by a controller  such as the REN48LSD, Simple Renard 32 or the REN64.  The REN48LSD and the  Simple Renard RGB+W CAN NOT drive these lights directly due to the high current demand per channel (~1.2A), you must use a DCSSR. A Standalone DMX Controller is available as a replacement controller as well. You must also use an additional constant current limiter if you use any replacement  controller.  On the LED board, each color channel consists of three separate LED circuits that each need to be separately  limited to 0.3A each, so you need a total of 9 constant current limiting devices per flood. Simple constant current drivers for each of the 9 circuits can be build using LM317 voltage regulators in a constant current configuration using resistors like this or this. A TIR Breakout board has been designed to provide constant current sources for the individual LED arrays.
TIR LED Breakout Board
A TIR Breakout Board has been designed and is being sold in a TIR Breakout Board Group Buy.  This board allows you to power the LED boards directly with a 24vdc power source.  To protect the LEDs from burning out, it is necessary to independently provide a constant current source to each of the 9 LED arrays.  This design provides the ability to drive 9 LED arrays with 3 inputs.  The design makes use of a LM317 configured to provide a constant 0.3A per LED Array using a circuit like this.
Breakout Board BOM
| Part Number | Description | Quantity |
| 538-87831-2420 | Headers & Wire Housings 2MM HDR. 24 CKT. Vert. SMT | 1 |
| 511-LM317T | Linear Regulators - Standard 1.2-37V Adj Positive 1.5 Amp Output | 9 |
| TBD | Resistor | 9 |
| TBD | Resistor | 2 |
| TBD | Resistor | 1 |
Breakout Board Schematic
 - The units all have a unique serial number that is listed on the label on the front face plate as well as a standalone sticker on the control module.  It looks like: 308-0911.  This number will be necessary for programming the lights.
 - 169.254.236.22 is TIR programming box address.
 - If ControlFX Director does not detect the presence of a DHCP server when connected to your notebook computer, the device will assume a default IP address of 169.254.236.22 and subnet mask of 255.255.0.0.
DMX Address Translation Board
Since these light responds to DMX Channels 1-3 out of the box, a board is under development to respond to any DMX address and translate it to channels 1-3 to drive these floods.  For more info look here.
Documentation
Destiny CG Wiring Schematic
Destiny CG Datasheet
Software
DMX Address Change Software
Thanks to a lot of detective work by the DIYC community the DMX address programming packets have been decoded and you are now able to reprogram the lights to any DMX address.  There are several tools available to set the address:
Reprogramming with just Vixen and an Enttec Pro compatible DMX dongle
Vixen Based Solution using modified PIC
Arduino Based Solution
SX based Solution
Address Packet Generator
Light Management
Light Initilization
Light Design and Emulation
Netburner
IP Setup tool
UDP Terminal Application
TIR Flood Discussion Threads
Initial Thread
DMX Address Change Details
Netburner Module
TIR Breakout Board
DMX Cable Adapter Boards
DMX Cable Adapter Board Group Buy
Test Pattern
Outdoor Test
Another outdoor test
Other Photos
