51fordf2
New member
Mike - do you have the chip programmed? It won't light up, until you do, and then it will blink as the "heartbeat" when running the diagnostic, the jumper on the 2nd set of pins. If you just power it on, and just see the "Vixen V.2", then it won't blink. At least that's how mine is working. Here's what the manual says:
Suggested Testing approach:
• Set jumper J2 to run the diagnostic sequence
• Power up the Ledtriks and the Triks C
• You should see a power LED on the Triks C
• You should see a splash screen followed by a scrolling diagonal and block on the Panel
It doesn't talk about the Diag LED, but I will be adding it...
There may be better answers...
Roger
Roger
