Go into the Library folder and find the file DebugGraphicsAdapter.txt.
When you engage Preview --- I write a LOT of information about what I find about your Graphic card and DirectX implementation.
THAT information can help greatly in figuring out what is going on.
Hope that helps.
Joe
FYI, here is the information when running under Wine.
Number of Adapters = 1
Requested Window Size W = 1280 H = 760
Adapter Size W = 1920 H = 1200 Refresh 60
Adapter Format 22 - D3DFMT_X8R8G8B8
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1920 H = 1200 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 960 H = 600 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1344 H = 840 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1280 H = 800 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1024 H = 768 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1024 H = 640 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 840 H = 524 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 800 H = 600 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 800 H = 500 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 640 H = 480 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1280 H = 960 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1344 H = 1008 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1600 H = 1200 Refresh 60
Adapter Size with Format D3DFMT_X8R8G8B8 --- W = 1600 H = 1000 Refresh 60
Failed Check Device Format D3DFMT_X8R8G8B8 D3DRTYPE_SURFACE, D3DFMT_X8R8G8B8
Failed Check Device Format D3DFMT_X8R8G8B8 D3DRTYPE_VERTEXBUFFER, D3DFMT_X8R8G8B8
Failed Check Device Format D3DFMT_X8R8G8B8 D3DRTYPE_SURFACE, D3DFMT_A8R8G8B8
Failed Check Device Format D3DFMT_X8R8G8B8 D3DRTYPE_VERTEXBUFFER, D3DFMT_A8R8G8B8
AdapterOrdinal 0
Caps 0
Caps2 1610743808
Caps3 800
PresentationIntervals 2147483649
CursorCaps 3
DevCaps 1683440
PrimitiveMiscCaps 2772978
RasterCaps 120791441
ZCmpCaps 255
SrcBlendCaps 16383
DestBlendCaps 9215
AlphaCmpCaps 255
ShadeCaps 541192
TextureCaps 126085
TextureFilterCaps 117638912
CubeTextureFilterCaps 117638912
VolumeTextureFilterCaps 50529024
TextureAddressCaps 63
VolumeTextureAddressCaps 63
LineCaps 31
MaxTextureWidth 8192
MaxTextureHeight 8192
MaxVolumeExtent 8192
MaxTextureRepeat 32768
MaxTextureAspectRatio 8192
MaxAnisotropy 16
MaxVertexW 1.000000
GuardBandLeft 0.000000
GuardBandTop 0.000000
GuardBandRight 0.000000
GuardBandBottom 0.000000
ExtentsAdjust 0.000000
StencilCaps 511
FVFCaps 1048584
Point Size Supported in FVF structure 1
TextureOpCaps 67043327
MaxTextureBlendStages 8
MaxSimultaneousTextures 8
VertexProcessingCaps 315
MaxActiveLights 8
MaxUserClipPlanes 6
MaxVertexBlendMatrices 0
MaxVertexBlendMatrixIndex 0
MaxPointSize 64.000000
MaxPrimitiveCount 1048575
MaxVertexIndex 1048575
MaxStreams 16
MaxStreamStride 1024
VertexShaderVersion 4294836992
MaxVertexShaderConst 256
PixelShaderVersion 4294902528
PixelShader1xMaxValue 8.000000
DevCaps2 81
Vertex Buffers containing transformed vertices from video 0
Vertex Buffers containing transformed vertices from system memory 1
MasterAdapterOrdinal 0
AdapterOrdinalInGroup 0
NumberOfAdaptersInGroup 1
VertexTextureFilterCaps 0
Driver - ati2dvag.dll
Description - ATI Mobility Radeon HD 2600
DeviceName - \\.\DISPLAY1
Driver Version Lo Hi - 6000E000A21E9
VendorId - 1002
DeviceId - 9581
SubSysId - 0
Revision - 0
OK Check Device Type D3DFMT_X8R8G8B8
PresentationInterval D3DPRESENT_INTERVAL_ONE OK
PresentationInterval D3DPRESENT_INTERVAL_IMMEDIATE OK
PresentationInterval D3DPRESENT_INTERVAL_DEFAULT Failed
