I know there are some super nice Tune To signs out there, and this is an attempt to collect them all in one thread. So post pictures, instructions, materials, everything you can for others to learn from.
Here is mine......
I started out with some .040 aluminum, luckily I worked with sheet metal fabrication equipment so bending the frame was easy. It could be made from wood though I guess. I used some self adhesive ziptie holders to hold on some 20ct strings. It ended up being 24X36 in size I think.
I bought a piece of Lexan locally and I drew the letters and numbers on the mask and cut them out using a razor blade. I then peeled the mask around them off and sprayed the Lexan black. After that dried, I peeled the remaining mask off and then sprayed it all LIGHTLY with silver paint. I think though a flat white would have been a better choice as the silver is a thick paint.
I did not like the look of the string minis so I bought a cheap CFL and screwed it to the bottom and that was a better look.
![sign1.jpg sign1.jpg](https://doityourselfchristmas.com/forum/data/attachments/12/12744-f3ddfdb521cce612c5495a9d097e7fde.jpg)
Here is mine......
![s1.jpg s1.jpg](https://doityourselfchristmas.com/forum/data/attachments/12/12741-af95b389d0bd07afc07024c09487ac0e.jpg)
![s2.jpg s2.jpg](https://doityourselfchristmas.com/forum/data/attachments/12/12742-af6d7b2f8d4d6a63b54c2529c04a9983.jpg)
![s3.jpg s3.jpg](https://doityourselfchristmas.com/forum/data/attachments/12/12743-63160a064d160f48037d8755735ae094.jpg)
