//this section maps channels to pins
#define CH01 2
#define CH02 3
#define CH03 4
#define CH04 5
#define CH05 6
#define CH06 7
#define CH07 8
#define CH08 9
#define CH09 10
#define CH10 11
#define CH11 12
#define CH12 13
#define CH13 A0
#define CH14 A1
#define CH15 A2
#define CH16 A3
#define CH17 A4
#define CH18 A5
#define CH19 A6
#define CH20 A7
#define CH21 A8
#define CH22 A9
#define CH23 A10
#define CH24 A11
#define CH25 A12
#define CH26 A13
#define CH27 A14
#define CH28 A15
#define CH29 22
#define CH30 23
#define CH31 24
#define CH32 25
#define CH33 26
#define CH34 27
#define CH35 28
#define CH36 29
#define CH37 30
#define CH38 31
#define CH39 32
#define CH40 33
#define CH41 34
#define CH42 35
#define CH43 36
#define CH44 37
#define CH45 38
#define CH46 39
#define CH47 40
#define CH48 41
#define channelCount 48
byte channels[] = {CH01,CH02,CH03,CH04,CH05 ,CH06,CH07,CH08,CH09,CH10,CH11,CH12,CH13,CH14,CH15,CH16,CH17,CH18,CH19,CH20,CH21,CH22,CH23,CH24,CH25,CH26,CH27,CH28,CH29,CH30,CH31,CH32,CH33,CH34,CH35,CH36,CH37,CH38,CH39,CH40,CH41,CH42,CH43,CH44,CH45,CH46,CH47,CH48};
void setup() {
//initialise the output pins you're using
for (byte i=0; i < channelCount; i++){
pinMode(channels[i], OUTPUT);
digitalWrite(channels[i],LOW);
//start the serial port
sei();
Serial.begin(57600);
void loop() {
while(true){//you need this for the 2 x continue statements to exit to
while(!Serial.available()); //pause if no new serial data
if(Serial.read() != '~') {
continue; //exit while loop if character is not 1st byte of header
if(Serial.read() != '!') {
continue; //exit while loop if character is not 2nd byte of header
for(byte i=0; i<channelCount; i++){
byte channelValue = Serial.read(); //read the next available byte from the serial buffer
//now turn the pin associated with the current channel on/off depending.....
if(channelValue < 127){
}else{
digitalWrite(channels[i],HIGH);
}//end of main 'while' loop
