I have a FM transmitter for my Kulp board which I am thinking about using. If I decide to use it, I won't need to transmit very far. From what I gather all I need for an antenna is about a 75-76cm wire soldered to the antenna pad. I have briefly toyed around with it on the bench and I do get output, although it is quite finicky, producing quite a bit of static, some of which I attribute to a shoddy test setup.
I have a few questions as I think about packing my enclosure:
1. How well will just a wire work inside an enclosure? Will it be affected by the 600W power supply also in there? or the wifi antenna I may have in there also?
2. How should I route this wire - inside the box or somehow bring it outside the enclosure?
3. Seems like it would be good to have a disconnect somehow instead of the antenna wire soldered to the board. How can I add a connector?
4. Should I consider the dipole antenna I have seen a design for or another type of external antenna attached to the outside of the enclosure? Are those options for this transmitter? In either case, how would I connect an external antenna to this board- center wire to antenna pad and the "shield/grnd" wire to any other GND on the transmitter board?
Appreciate your thoughts.
