Results 1 to 10 of 12
Thread: TA-200 leaking water
    Default TA-200 leaking water
    I have a TA-200 that seems to be letting water inside it from the top. I had a channel stick on the other day in the rain and it happened again yesterday in the rain. When i opened it up this morning i have pools of water seating on top on my heatsink and some seating in the bottom of the box too. The TA-200 lookis fine i don't seem any cracks or anything else and the box is mounted straight up and down like it should be. I have 15 others mounted the same way and now of them are taking on water???? Any ideas what or how the water would be getting in the SSR???
    Dec 2008
    3,364
    Default Re: TA-200 leaking water
    Is it traveling through the Ethernet cable?
    www.Kentucky-Christmas.com
    I do not think so the water is on top of the heatsink at the box and the ethernet cable is at the bottom of the box and going out of the box via a side entry rj45 jack. I think its coming in between the 2 halfs of the box now that i have pulled it and worked on it on the bench. I put a spacer in between the bottom case mounting screw and the surface its mounted on in hopes that it will cause the water to drain off the top before it gets deep enough to run in the seem of the box.
    Jun 2009
    Ottawa, Ontario, Canada
    2,494
    Could the water have gotten inside when you lifted the lid to open the box?
    (if you have a spare box.. swap it.. )
    Standard Disclaimers apply:
    Nov 2008
    Delphos OH
    1,171
    http://www.amazon.com/GB-Electrical-.../dp/B0038R7BP4
    use this stuff man. i have been rolling it like a snake and making my own seals for all my boxes. when you close it, it smashes and makes a great seal. awesome part is, its removeable, wont freeze, crack or anything. cheap too. can get at menards, lowes, hd for like 2 bucks for a 1lb brick. i also put where my connectors come out from the inside and out to seal it even more. molds like sticky tack and holds good.
    2012 - The year of the pixels
    21ft tall 12x38ct WS2811 Pixel Megatree - DONE
    5 36ct GECE Pixel Archs - Maybe
    Pixelated roofline with windows - DONE
    Bigger matrix and pixel star - DONE
    Added 1200 pixels, a few strobes, and fast tubes
    Now it just all has to play nicely lol.
    http://www.facebook.com/FiedlerFamilyChristmas
    Jul 2008
    3,208
    Quote Originally Posted by glaforce View Post
    Well these are mass produced plastic molds and you clearly have one that has some slack in the mgf tolerances. However, these are NOT designed to be waterproof as you are aware. Rope caulk has been used very successfully in sealing these better.
    Harrisburg, PA
    383
    One warning about "sealing them". If you make them airtight, they will condense, and you will have the same issue. They must have airflow.
    Left to Do:
    2011!!
    Spencer Iowa
    1,084
    Which way was the wind when you had leaking?
    They are designed to go against a house so the only direct wind would be from the front and sides.
    Joel
    If I no longer count channels... but instead say I have over 12 universes... Is that too many
    SF Bay Area
    414
    Quote Originally Posted by g2ktcf View Post
    I wasn't paying attention. Are any of the enclosures (CG-1500, CG-2000, ?) waterproof? I'm using these on a stake in the yard, not against the house. No problems yet, and we don't typically get heavy rain in sunny CA, so I may be OK. (We typically don't get 50+ MPH winds, either...)
    Tucson, AZ
    1,495
    I am not sure, so I place a small plastic trash can bag over each of my CG-1000 boxes. I twist them at bottom, but leave breathing access. Haven' t had an issue yet with water getting inside. Also hides them from the public.
