E1.31 Bridge
Revision as of 06:30, 23 March 2013 by Budude (talk | contribs) (Jumpers)
This is a work in progress!!!!
The 6-port E1.31 bridge is a device that takes in an E1.31 stream from your network and converts (or 'bridges') that to multiple DMX or Renard output streams. E1.31 or sACN (Streaming Architecture for Control Networks) is method of multiplexing multiple DMX streams over your network using unicast or multicast UDP packets. The 6-port bridge currently only supports multicast streams. This makes it simpler to configure but has drawbacks in very large configurations (10's of streams). E1.31 can support 64K worth of DMX streams or 'universes' so it has a virtually unlimited amount of expansion available.
The bridge has another feature so that each physical output can be re-wired to support with a "standard" DMX RJ-45 output or a Renard output without resorting to making custom cables to support either. The output of the bridge is always RS-485 in either case. Note that regardless if your Renard controller is running standard Renard/Serial code or Renard/DMX code, the jumpers should always be configured for Renard since the physical interface does not change.
6 Port E1.31 Bridge Parts
Mouser BOM
Mouser PNDescriptionQty
The 6 Port E1.31 Bridge requires a fair bit of soldering so take your time and ensure you install the components in the correct orientation when required. Start by sorting the components by type and values. Look over the PCB before starting noting the location of the various components. Follow the standard procedure of installing the lowest profile parts first and ending up with the tallest.
  1. Install the 0.1uF (100nF) capacitors C4-C12.
  2. Install the 220 Ohm resistors R1-R3.
  3. Install the 120 Ohm resistors R4-R9.
  4. Install the 10K Ohm resistors R10-R12
  5. Install the 5Mhz Crystal X1.
  6. Install the Toggle Switches S1-S2.
  7. Install the seven 8 Pin IC sockets and one 40 pin socket.
  8. Install the green LED LED1.
  9. Install the red LEDs LED2-LED3.
  10. Install the 3.3V Regulator VR2 with the heat sink.
  11. Install the 3 Pin and 4 Pin headers JP1, H1.
  12. Install the two WizNet 1x6 pin headers.
  13. Install the twelve 2x3 output pin selectors.
  14. Install the power terminal block TB1.
  15. Install the three 47uF Capacitors C1-C3.
  16. Install the DC-DC Converter VR1.
  17. Install the six RJ45 jacks J1-J6.
  18. Install the six RT485BN in IC3-IC8 with the notches facing the edge with the power terminal block.
  19. Install the EEPROM in IC2 with the notch facing the edge with the power terminal block.
  20. Install the Propeller in IC1 with the notch facing the WizNet adapter.
  21. Install the WizNet adapter with the socket facing the Propeller IC.
H2 and IC9 will be unpopulated as these are both for future expansion.
Jumpers
Power Jumper - JP1
This jumper determines whether the power provided on the DC input terminal block goes directly to logic on the board or if it goes to the 5v voltage regulator and then to the 3.3v regulator. If you apply +5vdc to the terminal block, you should put the jumper on the "EXT" setting (indicates you are getting 5v externally). If you apply +7-24vdc, you should put the jumper on the "INT" setting (indicates you are getting 5v internally).
You MUST ensure you have this jumper set correctly if you are using voltages greater than 5v as it may (and probably will) cause permanent damage to some components on the board. The Propeller chip uses 3.3v but the RS-485 transceivers are 5v devices and would be probably be damaged.
Output Configuration Jumpers
Each port has a set of four separate jumpers. If you want a DMX output, you need to put all four jumpers to the "DMX" side. If you want a Renard output, you need to put all four jumpers to the "REN" side. It is important that all four jumpers are in the same position for that port.
When configured for DMX, the output would be:
Pin 1 - RS-485 D+
Pin 2 - RS-485 D-
Pin 7 - Signal Ground
Pin 8 - No Connection
Pins 3, 4, 5, and 6 have no connection.
When configured for REN, the output would be:
Pin 1 - Signal Ground
Pin 2 - Signal Ground
Pin 4 - RS-485 D-
Pin 5 - RS-495 D+
Pins 3, 6, 7 and 8 have no connection.
Powering the E1.31 Bridge
Initial Testing
Programming the EEPROM
Current version of the firmware is v2.03 and you can download it here.
The Programming port on the Bridge is the 4 pin header near the WizNet adapter. Match up the silk screen labels with those on the Prop Plug. You will need to externally power the bridge when programming it.
Programming Tools Required
The reccomended way is to use the PropPlug.
PropPlug
You can get it from DIYLEDExpress during Pre-Sales or find it at Parallax or Mouser anytime.
Build your own
Programming Howto
  • Download the Parallax Propeller Tool and install it.
  • Run the Propeller Tool application and it will ask of you want to associate .eeprom files with the application, Say Yes.
  • You can close the Propeller Tool application and double click on the .eeprom file you downloaded or from within the application go to File->Open and change the 'Files of type' to 'Propeller Applications' and open the Bridge_v2.02.eeprom file.
  • A 'Object Info' screen will open, if not already enabled click 'Show Hex'
  • Program the EEPROM on the Bridge by selecting 'Load EEPROM' and you are done.
http://doityourselfchristmas.com/wiki/index.php?title=E1.31_Vixen_Plugin
Configuration Commands
Save
Load
Boot
IP
IP a.b.c.d where a.b.c.d is any valid IP address
Subnet
Gateway
DNS
If you are only using DHCP (not recommended), you can leave the static IP areas unused. Network addressing (static or DHCP IP) is only needed to access the configuration page with a web browser. Once configured, no IP address is needed for normal operation. The Default IP Mode, Web Server Mode, No Data Timeout, and Test Pattern commands affect what happens when the system starts up.
Default
DEfault n where n is 0 or 1. DE 0 sets a default network mode of STATIC, DE 1 sets a default network mode of DHCP.
Universe
Protocol
Baud
The Baud command is used to set the baud rate for each of the four output RJ45 jacks. NOTE: This command is only used for the Renard protocol. Baud rate will not be displayed when the DMX protocol is selected.
BAud b n Where b is the RJ45 output jack number, from 1 to 6 and n is 1 for a baud rate of 57,600 or 2 is for a baud rate of 115,200. The Renard protocol refresh rate at 57,600bps for 512 channels is approximately 90ms and at 115,200bps the refresh rate for 512 channels is approximately 45ms. The DMX protocol refresh rate is preset to 25ms.
TroubleShooting
Visual Inspection
Power
EEPROM Programming
Communications
Network Configuration
--Dlovely (talk) 11:47, 29 November 2012 (EST)
