Creating Basic Effects
Current as of Version 12Z.
The HLS Sequencing Window has four basic components which are important when sequencing (See Figure 5-1).
Selection Mode in HLS
Basic Method to Create a Selection Box:
Basic Effects
Level:
- Shortcut key: L
Ramp Up:
- Shortcut key: U
Ramp Down:
- Shortcut key: D
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
- Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
Modify Effect Attributes:
| Chapter 4: Display Preview | Chapter 5: Sequencing Channels and Adding Effects | Adding and Using Beat Tracks |
