Template:Infobox image/doc
Template:Documentation subpage
Usage
This template inserts an image with borders that look like that of Template:Infobox. Use this template when you need to stack images vertically with an infobox template, such as Template:Tl, Template:Tl, Template:Tl or Template:Tl.
Syntax
{{#if:title|}} {{#if:|}}{{#if:|}}{{#if:{{#if:|| {{{above}}} | |
| {{{subheader}}} | |
| {{#if:| }}{{#if:||[[File:Example.jpg{{#ifeq:|yes||border}}||alt=Picture]]}}{{#if:| }} {{#if:|{{{caption}}} }} | |
| {{#if:caption|caption|}} | |
{{Infobox image
|title = <!-- image title -->
|name = <!-- image name -->
|size = <!-- width -->
|has border = <!-- yes or no -->
|caption = <!-- image caption -->
Parameters
| Parameter | Description |
| title | subst:}}Infobox aviation{{#if:|
|{{{2}}} }}{{#if:| |{{{3}}} }}{{#if:| |{{{4}}} }}{{#if:| |{{{5}}} }}{{#if:| |{{{6}}} }}{{#if:| |{{{7}}} }}{{#if:| |{{{8}}} }}{{#if:| |{{{9}}} }}{{#if:| |{{{10}}} }}{{#if:| |{{{11}}} }}{{#if:| |... }}}} but in above and used for aviation only. |
| name | Mandatory: Image file name (including its extension) You do not need to include "File:" prefix or "Image:" prefix. |
| size | Highly-recommended: Width of the intended image in pixels. |
| has border | Optional: Indicates whether a light border should be drawn around the image. Can be set to "yes" or "no". Default is "no". Do not use this parameter when the image has a transparent background. Do not confuse this border with the black border which is always present around the infobox. |
| caption | Optional: A text to be written below the image. |
Example of use
{{#if:|}}
{{#if:|}}{{#if:|}}{{#if:{{#if:| }}{{#if:||[[File:Mozillaheadquarters.jpg{{#ifeq:no|yes||border}}|250px|alt=Picture]]}}{{#if:| }}|}}{{#if:|| {{#if:|{{#if:{{#if:Former office next to the Googleplex shared by both the Mozilla Foundation and the Mozilla Corporation until July 2009|Former office next to the Googleplex shared by both the Mozilla Foundation and the Mozilla Corporation until July 2009|}}|}}| {{#if:{{#if:Former office next to the Googleplex shared by both the Mozilla Foundation and the Mozilla Corporation until July 2009|Former office next to the Googleplex shared by both the Mozilla Foundation and the Mozilla Corporation until July 2009|}}|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|| {{#if:|{{#if:|}}| {{#if:|}} }} }}{{#if:|}}
See also
|{{{2}}}
}}{{#if:|
|{{{3}}}
}}{{#if:|
|{{{4}}}
}}{{#if:|
|{{{5}}}
}}{{#if:|
|{{{6}}}
}}{{#if:|
|{{{7}}}
}}{{#if:|
|{{{8}}}
}}{{#if:|
|{{{9}}}
}}{{#if:|
|{{{10}}}
}}{{#if:|
|{{{11}}}
}}{{#if:|
{{{{#if:|subst:}}File title{{#if:|
|{{{2}}}
}}{{#if:|
|{{{3}}}
}}{{#if:|
|{{{4}}}
}}{{#if:|
|{{{5}}}
}}{{#if:|
|{{{6}}}
}}{{#if:|
|{{{7}}}
}}{{#if:|
|{{{8}}}
}}{{#if:|
|{{{9}}}
}}{{#if:|
|{{{10}}}
}}{{#if:|
|{{{11}}}
}}{{#if:|
|{{{2}}}
}}{{#if:|
|{{{3}}}
}}{{#if:|
|{{{4}}}
}}{{#if:|
|{{{5}}}
}}{{#if:|
|{{{6}}}
}}{{#if:|
|{{{7}}}
}}{{#if:|
|{{{8}}}
}}{{#if:|
|{{{9}}}
}}{{#if:|
|{{{10}}}
}}{{#if:|
|{{{11}}}
}}{{#if:|
|{{{2}}}
}}{{#if:|
|{{{3}}}
}}{{#if:|
|{{{4}}}
}}{{#if:|
|{{{5}}}
}}{{#if:|
|{{{6}}}
}}{{#if:|
|{{{7}}}
}}{{#if:|
|{{{8}}}
}}{{#if:|
|{{{9}}}
}}{{#if:|
|{{{10}}}
}}{{#if:|
|{{{11}}}
}}{{#if:|
