The PixelPlane Editor: Vertical Matrix
Current as of Version 12P.
These sections need to be completed: Horizontal/Vertical Bitmap, Animated GIF.
Diagonal
A Diagonal effect creates a diagonal "striping" that slides across the matrix.
The Options to customize the Diagonal Effect:
- Speed of Rotation: How fast should the Diagonal lines slide.
- Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
- Width of Bars: How wide the bars should be.
- Diagonal: Angle of diagonal lines.
Vertical Bars
A Vertical Bar effect creates vertical bars that slide across the matrix.
- Speed of Rotation: How fast should the bars slide (lower numbers mean faster).
- Number of Bars: The number of bars to slide vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
A Horizontal Bar effect creates horizontal bars that slide up or down the matrix.
Snow
A Snow effect creates random snowing of randomly colored pixels in the matrix.
- Sparkle: Effects how many snowflakes are white. To have all white snow, turn it up very high.
Meteors
A Meteors effect creates random meteors that streak down the matrix.
Fireworks
A Firework effect creates fireworks that streak down the matrix. These are exactly the same as meteors, except when sparkle is applied. When it is applied, it will randomly "explode" the firework.
- Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
Horizontal/Vertical Text
A Horizontal or Vertical text effect displays text that moves across the matrix either horizontally or vertically.
- Special note on Text: Strings are oriented with string 1 in the left-most position. So, you most likely want the "injection position" to be at the right-most string position, so that the text will start at the right of the matrix and run to the left across the matrix.
- Speed of rotation: How fast the text will move across the matrix.
- Snow Density: This controls the amount of snow to appear with your text. (Must Check "Add Snow to Text")
- Note: You must click the Generate Text button before it will display in the animation window. Any changes made to text REQUIRE the generate text button to be pressed again.
Hide Text Strings:
- This allows you to turn off certain strings of the matrix.
A Horizontal or Vertical Bitmap effect generates a bitmap file that scrolls across the tree horizontally or vertically.
Options to Customize a Bitmap Effect:
- Speed of Rotation: How fast the bitmap should rotate horizontally or slide vertically.
- Injection Height: What height (in pixels) to start the bitmap.
- Sparkle: Add random sparkling to the bitmap.
Selecting the Bitmap:
- Click the Bitmap File button and open your desired bitmap file.
- Click the Height and Width buttons to let HLS know the dimensions of your file.
- Click the Generate Bitmap file to complete setting up the file. Any changes to the file will require pressing the Generate Bitmap button again.
| The PixelPlane Editor: MegaTree | Chapter 6: The PixelPlane | Using Nutcracker with a PixelPlane |
