Advanced Channel Management
This is based on version 11V.
- Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware.
- Order: This field is used to adjust the order of the channels.
- Multiple DMX Group: A normal DMX universe has 512 channels. This is active when using hardware that allows 4096 channels per universe.
- Display X / Display Y: These numbers are calculated by using the Display Preview and allow the user to plot pixels on an X/Y axis which will allow controlled effects such as color sweeps from left to right or top to bottom. (This is not yet fully implemented.)
Advanced Renaming Channels
Rename Individual Channels:
- When done, Click Save All Channels.
Bulk Channel Renaming:
Method One:
- Examples:
Method Two:
Reordering and Renumbering Channels
To ReOrder channels:
- Once the channels have been ReOrdered, click Renumber All Channels for Output to update the Order column (and the Channel column if Universe is greater than zero).
- Click ReOrder Channels.
- Click Renumber all Channels for Output.
Using Folders
Create a New Folder:
To remove channels from a folder:
Opening and Closing Folders:
Folder Tutorial Video: here
Copying Channels
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 3-20). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Deleting Channels
| Figure 3-21: Click the Delete Selected Channels button. |
| Figure 3-22: Confirm you wish to delete by clicking yes. |
| Figure 3-23: HLS will prompt to shut down to update its configuration. Click OK. Then OK again. |
Program Help File
| Setting up HLS Channels | Chapter 3: Channel Management | RGB Channels |
