Creating Basic Effects
Under Development.
Based on Version 11V.
The Window and it's components
The Toolbar and relevant buttons
Selection Mode in HLS
Basic Method to Create a Selection Box:
 - All of the cells you have chosen will be surrounded by a dotted line. (See Figure 4-X).
Basic Effects
Level
Ramp Up
Ramp Down
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
 - Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
Modify Effect Attributes:
 - Right-click an effect and select Modify Effect. The Modify Effect window will appear (See Figure 5-X).
