Advanced Channel Management
Revision as of 20:08, 29 January 2013 by Jlowe (talk | contribs) (Using Folders)
This is based on version 11V.
This portion of the manual is under heavy development.
Figure 3-10
  • Left-most Gray Square: This is a selection box. You left-click in here and the square becomes green. That channel (and any others you left-click on) is selected and can be moved into a folder or deleted.
  • Name: This field shows the name of the channels.
  • Universe: A numerical value from 0-5000. Any channels in universe 0 will never be displayed.
  • Channel: This is the numeric value of the channel. These are used when the sequence is sent to controlling hardware.
  • Color: This field is set to the color of the channel.
  • RGB: This checkbox is checked when a channel is an RGB lighting element or pixel.
  • Dimming Curve: This field is to set a dimming curve for the channel.
  • Order: This field is used to adjust the order of the channels.
  • Folder: The number of the folder that a channel is assigned to.
  • Multiple DMX Group: A normal DMX universe has 512 channels. This is active when using hardware that allows 4096 channels per universe.
  • Control Type: This is used with animation effects and trigger events.
  • GRB: Used when the order of the RGB is different from Red-Green-Blue.
  • Preview Group: This group number defines what Preview Group the channel belongs to.
  • Preview Number: This is the channel number for the assigned display group.
Advanced Renaming Channels
Figure 3-10
To rename individual channels, you must first open the Channel Manager (Manage Channels -> Manage Raw Channels). See Figure 3-10.
  • Check the box to Unfreeze Name to Edit.
  • Click on the channel you wish to rename.
  • Highlight the old name and type in the new name.
  • When done, Click Save All Channels.
Reordering and Renumbering Channels
Using Folders
Figure 3-11
Figure 3-12
Create a New Folder:
  • Open the Channel Manager (Manage Channels -> Manage Raw Channels).
  • Click the Add Folder button on the top toolbar. (See Figure 3-11).
  • A dialog box will open asking for a Folder name. Type name and press OK. (Se Figure 3-12).
    • Note: A Super Folder contains only folders. Check this box if you wish to create a "folder of folders". This would be used for channel organization.
  • Once entered, the folder will appear at the top of the list of channels and have ++ on the left-most square to identify it as a folder. (See Figure 3-13).
Figure 3-13
Copying Channels
Revisions needed.
2013-01-21 Confirmed the following works exactly as stated on version 11V.
To copy one or more channels click on the channel and asterisks will appear to the left of the channel name (see Figure 1-20). The click again on the channel to select it. Then Select the Manage Channels tab and choose Copy - Paste Whole Channels. You will then be prompted to Click on the Channel to Paste To.
Figure 1-20
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 1-21). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Figure 1-21
Deleting Channels
Program Help File
Paste help file from HLS channel manager here.
Setting up HLS Channels Chapter 3: Channel Management RGB Channels
