PIXEL CONTROLLERS
SanDevices
Joshua 1 Systems (J1SYS)
Stellascapes
| E16-II Pro | 672 | 6Unicast | Stella-black | 16 Fused (? Electrical, ? Logical) | 2016 | ? | link | Assembled Board: $?? | With power supply and Neutrik XLR, power and ethernet chasis connectors |
DMX512 to SPI
J1Sy
- uDCG-P2
 - DCG-P2
AVD
ACL
Onumen
RPM
Ray Wu
Stellascapes
- T3: DMX512 - SPI Bridge
- E2: Ethernet - SPI Bridge
PIXEL Extenders
ECG-PPX
E1.31 Bridges and DMX Dongles
DIYLEDEXPRESS
- ECG-D8
 - ECG-DR4
 - ECG-D4
 - ECG-D2
RPM
USB to DMX512
 - Enttec Open DMX USB
 - Enttec DMX USB Pro
 - RPM DIY USB to DMX Adaptor
FTDI drivers for dongles:
RGB Controllers Feature Comparisons
| Audiolight Intl | HD-714 [1] [2] | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
| Audiolight Intl | HD-712 [3] [4] | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
| Leynew | LN-DMXMODEL-3CH-LV12 [5] [6] | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
