PIXEL CONTROLLERS
Ethernet (E1.31) to SPI
SanDevices
Joshua 1 Systems
Stellascapes
- Stellascapes Stellascapes E2 & E16 Ethernet to 2 / 16 SPI (pixel) outputs
E16-II Controllers
The E16-II controllers are Stellascapes flagship controllers for SPI based RGB Led fixtures. Based on Stellascapes successful E16-I, the E16-II brings a number of improved features, and and increased range of ready to use configurations. All variants share a number of key features;
       Art-net II, or Streaming ACN ( E1.31 ) input protocols - DMX over IP.
       10/100 Megabit Ethernet
       16 output strings, each individually configurable for addressing
       Easy to use web based GUI for control
       On Board Single RGB LED for system testing without the need to have attached string
       16 Character LCD Display for diagnostics and identification information.
E16 - Commercial
The E16-II Commercial controller is a ready to install system designed for permanent or low movement installations, such as permanent theme park installations, or holiday lighting. Enclosed in a high impact, UV resistant case the E16-Commerical includes an integrated mains power supply ( 110-250VAC 50/60Hz ), providing 320W of power, sufficient to fully power 672 RGB pixels. Waterproof Cable glands provide an mechanism for cable entry for UTP and Mains. Splash proof venting systems are used to duct air in and out of the system for active cooling. 16 400mm "tails" with waterproof screw up connectors are provided for interconnection to the strings. Each String is individually fused to provide protection in the event of a failure or breakage.
E16-Bare
The E16-II is available as a set of "bare-board" assemblies. The boards includes the microprocessor and associated circuitry, software, ethernet interconnectivity and buffered outputs. Bring your own case, power supply, output connectors. Perfect for the do-it-yourselfer , or where the system needs to be build into something where the commercial or Pro systems just won't work. Note Stellascapes does not provide a PCB only option.
DMX512 to SPI
 - RPM Pixel Bridge
TP3244 Pixel Driver
- Controlled through: DMX
RPM WS2801 to DMX Pixel Bridge
T3: DMX512 - SPI Bridge
E2: Ethernet - SPI Bridge
USB to DMX512
 - Enttec Open DMX USB
 - Enttec DMX USB Pro
 - RPM DIY USB to DMX Adaptor
FTDI drivers for dongles:
PIXEL Extenders
ECG-PPX
RGB Controllers Feature Comparisons
| Audiolight Intl | HD-714 [1] [2] | Yes | 12V - 24V | 3 | 2A | 6A | DMX | $8.95 | $2.98 |
| Audiolight Intl | HD-712 [3] [4] | Yes | 12V - 24V | 27 | 1A | 15A | DMX | $44.21 | $1.64 |
| Leynew | LN-DMXMODEL-3CH-LV12 [5] [6] | Yes | 12V | 3 | 2A | 6A | DMX | $7.49 | $2.49 |
