This User Manual and Reference Guide is a detailed guide to using all aspects of HLS. It is currently under significant development. To quickly get up and running with a sequence, you may want to look at the HLS Getting Started Manual. Due to the rapid development of HLS, each of the links will contain, in parenthesis, which version of HLS was used to create that portion of the manual. That way, it will be easy for others to determine which portions are up to date and which are out of date with a quick visual inspection.
Getting HLS
Upgrading HLS (11V)
Creating a Sequence
Audio File (11V)
Time Resolution (11V)
Channel Management
Setting up HLS Channels (11V)
Advanced Channel Management
RGB Channels
Using Folders
Configuring Display Groups
Sticky Channels
Importing and Exporting
Comma-Separated Values (CSV)
Importing a Sequence from Vixen
Importing a Sequence from LOR
Moving or Sharing Sequences
Sharing Library Effects
Display Preview
Dimming Curves
Dimming curves can be used to give the appearance of a more "natural" ramp on and off to LED lights.
Setting up Dimming Curves
Adding and Using Beat Tracks
Creating Basic Effects
Setting Defaults for Level, Ramps, and min/max out
Creating Chase Effects
Mirroring Effects
Fill Effects
Over Control Effects
Custom Effects
Creating a Library of Group Effects
The PixelPlane
PixelPlane Editor
MegaTree
Sequence Playback
Sequence Playback
Play from a Mark
Sequence Output
Hardware Configuration
Selecting the Output Method
Working with Playlists
Trigger Events
RDS Output
Servo Motors
