24 Channel Renard with SSR Assembly Instructions
Revision as of 13:40, 8 October 2007 by Fkostyun (talk | contribs) (BOM)
Layout
COOP PCB V2.5
PCB
1  TBA                   Renard 24-Port PCB
511-BTA08-400B 24
579-PIC16F688-I/P 3
571-7969494 1
595-SN75176BP 2
511-L7805CV 1
821-DB102G 1
571-2828376 4
271-680-RC 28
532-7136DG 1
271-180-RC 24
271-27K-RC 3
271-1K-RC 4
571-5564161 2
271-120-RC 1
859-MOC3023 24
625-1N4001-E3 1
78-1N5239B 3
838-3FD-320 1
782-H11AA1 1
520-TCF1843-X 1
140-HTRL25V1000-RC 1
140-HTRL25V10-RC 1
140-HTRL16V100-RC 1
534-3517 4
504-GMA-15 2
Also need:
5 .1uF capacitors
4 3 pin headers
4 .100 shunts
3 LED's
Design Notes
The anode pin of the 1N4001 diode is on the top.
 1/20/2007 Initial Design
 3/20/2007 Revision 2 submitted to test manufacturing.
 7/15/2007 Changed RJ45 to comply with current Renard standards.
 7/15/2007 Added additional holes for a larger transformer.
 7/15/2007 Added transformer voltage selection jumpers, will allow for 120/240v operation.
 7/15/2007 Changed fuse size to 5x20mm fuse from AG3 fuse.
 7/16/2007 Added option for DIP or SMT MOC2032 optos.
 8/20/2007 Version 2.5 submitted to test manufacturing.
Errata for Rev 1 PCB -
 1) Onboard regulator not functioning properly: needed addition of 1000uF capacator.
 2) Outputs are out of order.
 3) Triacs are located to close together.
Errata for Rev 2 PCB -
 1) Outputs 17/18 are swapped.
 2) RS485 traces swapped.
