Revision as of 05:23, 25 January 2013 by Jlowe (talk | contribs)
[Back to HLS Main Page]
This User Manual and Reference Guide is a detailed guide to using all aspects of HLS. It is currently under significant development. To quickly get up and running with a sequence, you may want to look at the HLS Getting Started Manual.
Getting HLS
Download and Installation
Upgrading HLS
Creating a Sequence
Starting a new HLS Sequence
Audio File
Time Resolution
Channel Management
Setting up HLS Channels
Configuring Display Groups
Adding and Deleting Channels
RGB Channels
Pixel Channels
Converting 3 Channels into a Single RGB Channel
Using Folders
Displaying a Group in the Main Window
Importing and Exporting
Comma-Separated Values (CSV)
Importing a Sequence from Vixen
Importing a Sequence from LOR
Moving or Sharing Sequences
Sharing Library Effects
Display Preview
Creating a Display Preview
Dimming Curves
Dimming curves can be used to give the appearance of a more "natural" ramp on and off to LED lights.
Setting up Dimming Curves
Adding and Using Beat Tracks
Creating Basic Effects
Setting Defaults for Level, Ramps, and min/max out
Creating Chase Effects
Mirroring Effects
Fill Effects
Over Control Ramp
Custom Effects
Creating a Library of Group Effects
The PixelPlane
A PixelPlane is a single channel in the sequence editor that represents multiple pixels. This allows macro control of pixels, with the ability to "drop" effects onto a plane, such as with Nutcracker, and manipulate the entire effect as if it was one channel.
[[PixelPlane Editor]
MegaTree
Sequence Playback
Outputting the Sequence
Hardware Configuration
Selecting the Output Method
Working with Playlists
Trigger Events
RDS Output
Servo Motors
