FM02 Gallery
Pictures of Various FM02 and other VAST product Installations
			By OregonLights.
FM02
			By OregonLights.
FM02
			By Underdog.
FM02
			By Underdog.
FM02
			By CaptKirk.
FM02
Mounted in an Aluminum case -
			By chelmuth.
FM02
			By chelmuth.
FM02
			By smartalec.
FM02
			By RobDude30.
FM02
			By RobDude30.
FM02
			By rkhanso.
FM02
			By rkhanso.
FM02
			By klanger.
			By AURBO99.
My FM02 was installed in an old CD-ROM case. It includes the miniRDS unit.
			By AURBO99.
My FM01 installation in a Hammond project box. It includes the miniRDS unit.
			By imbluenote.
			By kingofkya.
			By dmcole.
1 Watt VAST unit
			By rogelio.
FM02 with MicroRDS unit
			By rfallatt
FM02
			By rfallatt
FM02
			By rfallatt
FM02
			By SamJ435.
			By SamJ435.
			By pcoshatt
FM02
			By pcoshatt
FM02
			By hasoon
FM02 with Wall Wart Tamer
Here is my FM02 build using a gutted Sony A/V switch I picked up at a Boy Scout rummage sale. The other stuff you see in the case is my own home grown Wall Wart Tamer, 3.5 to 3.5 panel mount jack and a 6" 3.5 to 3.5 jumper all from MCM Electronics. Then I have a SMA-BNC panel mount from Ebay.
