E1.31 (Streaming-ACN) Protocol
Revision as of 21:02, 20 August 2012 by Jklingert (talk | contribs) (Tools: added da_E131 link)
A ratified/offical copy of the standard can be purchased here for about $40.
Protocol Description
sACN is ethernet based and is sent via UDP. The two accepted transport methods are multicast and unicast, the most common implementation is multicast. When using multicast all the controller needs to do is subscribe to the multicast address for the universe that you want to receive data from.
More Information
Description
Code Example and Draft Copy of Specification
Article: E1.31: An Offer You Can't Resist
Streaming-ACN (E1.31) with Vixen
Plug-in
Discussion about Protocol
Tools
sACNView: Sends and Receives Streaming-ACN
da_E131: Sends Streaming-ACN
