DCSSR
Revision as of 22:03, 15 August 2012 by Jklingert (talk | contribs) (DCSSR - DC Solid State Relay: added photos)
DCSSR are used to switch medium/high current DC loads such as high power LEDS, Dumb RGB Strips, DC Floodlights, solenoids, etc. They allow the high current switching element to be electrically isolated from the input computer signal driving the channel for safety. They are generally driven by a computer or a controller like a Renard 64XC, Ren48LSD or Simple Renard 32 Combo hooked to a computer to provide the signaling to turn the DCSSR channels on and off. They are generally connected to to the controller using low power 5VDC signaling. Their outputs are connected to N-Channel MOSFETs that act as switches. The power for the DC load is connected directly to the DCSSR and is switched by the MOSFETs and the power is available on the output terminal strips.
Version 1.0 - 1.3
For detailed information about the original design layouts Versions 1.0 - 1.3 by John Wilson (wjohn) look here
Version 2.4
For detailed information about the Version 2.4 layout by Andrew Williams (LabRat) look here
