The Simple Renard Series
Revision as of 18:58, 15 August 2012 by Jklingert (talk | contribs) (Simple Renard 32 Combo: added description of the sr32)
THIS WIKI IS A WORK IN PROGRESS. PLEASE CHECK BACK FOR UPDATES
THIS WIKI IS ABOUT THE SIMPLE RENARD SERIES OF CONTROLLERS, NOT THE SS SERIES OF CONTROLLERS
FOR INFORMATION ABOUT THE SS SERIES OF BOARDS GO TO: SS24 SS16 SS8
The Simple Renard Series are a PIC microcontroller based Christmas light controllers with 16, 24 or 32 channels that connect to AC SSR's, DC SSR's or DC Floods. The board design is based on the PIC-based 8-port dimmer concept originally developed by Phil Short. Information on the original concept can be viewed here. Generic information pertaining to current Renard designs (including maximum channel count) can be found on the Renard wiki page.
The Simple Renard Series controllers are part of a design effort to standardize the board layouts for Renard based systems and to establish a standardized list of components to use in Renard designs.
  • On-board LEDs for status of ZC, HB FE and TX/RX signals.
The Different type of Simple Renard Boards
Simple Renard RGB+W
Simple Renard RGB+W
The Simple Renard 32 combo is a low cost 32 channel controller designed to drive either ACSSRs or DCSSRs which switch their loads close to the item being controlled. Unlike other Renard designs like the Renard 64XC, the Simple Renard 32 Combo makes use of a different PIC, the PIC18F4520. This PIC allows 32 chanels per PIC to be controlled compared to the usual 8 channels per PIC (16F688) used in most Renard designs. This allows a smaller board and lower total cost.For more info go to Simple Renard 32 Combo
Simple Renard 24
Simple Renard 24/6
Simple Renard LCC 16
Simple Renard 8
Board Availability
Visit N7XG Site for board availability.
